How to read a dwell meter
  • ckahleer
  • ckahleer's Avatar Topic Author
10 Oct 2023 21:58
#890335
I have an old anolog dwell meter. It has a switch labled 4/8 cyl - 6 cyl.
I have an 82 kz305 and a 79 KZ400. The 305 has a set of points for each cylinder, and the 400 has 1 set of points for both cylinders.
Up till now, I have been setting points with a feeler gage, but would like giving this dwell meter a try.
What switch setting should I use, and is there a factor to multiply or divide the readings by?
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: How to read a dwell meter
11 Oct 2023 07:37
#890340
Mind you, it's been since the '70s,   but IIRC you will have to set it to 4/8 cylinder, and then multiply the reading by 4 for the twins... I think?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
11 Oct 2023 10:14
#890349
Does the 305 have two "single output" coils and the 400 one "double outlet" coil (lost spark)
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
11 Oct 2023 11:44
#890353
I actually recently found my old Heathkit automotive tach/dwell meter I built in the seventies.
I would set the proper point gap with the feeler gauges then attach the dwell meter and fiddle around with the knob until you get a dwell reading you can deal with. Reverse engineering, sorta.
  • ckahleer
11 Oct 2023 13:02
#890356
Yes, The 305 has two sets of points and two single output coils. It has a 180 crank. When one piston is at TDC the other one is down.
The 400 has one set of points and 1 dual output coil. Pistons move up and down together.
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
11 Oct 2023 13:09
#890357
Not sure if this will be of help or not but there are several topics/posts on this subject that a search will reveal.  I found this one to be of interest.
kzrider.com/forum/21-tools/616065-how-to...d-dwell-meter#850216
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
