Sprockets
  • ellwinger
  • ellwinger's Avatar Topic Author
Re: Sprockets
14 Jul 2023 20:16
#887227
Everything checks out. Am I not getting enough gas? Jets? Low fuel flow?
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Sprockets
14 Jul 2023 23:06
#887234
Do you know what size pilot and main jets are currently installed?
1982 KZ1100-A2/1170 sleeper 😀
  • Buzz Nichols
  • Buzz Nichols's Avatar
Re: Sprockets
15 Jul 2023 02:21
#887236
NOW IS THE TIME ON SPROCKETS WHEN WE DANCE!!
Tsank you, Dieter.
1978 KZ1000 LTD
  • TexasKZ
  • TexasKZ's Avatar
Re: Sprockets
15 Jul 2023 03:54 - 15 Jul 2023 03:55
#887237
Is there an inline fuel filter with a paper element?
All the valves have the proper lash?
Fuel levels are correct?
Last edit: 15 Jul 2023 03:55 by TexasKZ.
  • hardrockminer
  • hardrockminer's Avatar
Re: Sprockets
15 Jul 2023 04:18
#887238
Assuming your diagnosis is correct you should begin checking your gas system.  Pull your fuel line and check the flow from the petcock.  Watch it for about a minute to see if it slows down.  That will indicate you have a problem with the air breather on the gas cap.  If fuel flow is fine then move to the carbs to check them for fuel flow.  Is anything blocking the fuel lines?
  • ellwinger
Re: Sprockets
15 Jul 2023 09:20
#887255
Don't know the pilot size but the mains are 107 and the needle in the 4th position.
  • ellwinger
Re: Sprockets
15 Jul 2023 09:22
#887257
Yes, don't know, yes.
  • ellwinger
Re: Sprockets
15 Jul 2023 09:23
#887258
I'll check.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Sprockets
15 Jul 2023 11:19
#887263
If all else fails check nothing is obstructing the exhaust (what goes in needs to come out)
  • TexasKZ
  • TexasKZ's Avatar
Re: Sprockets
15 Jul 2023 21:06 - 15 Jul 2023 21:10
#887285
I am going to guess this is a response to my last post. As a rule, filters with paper elements are for pressurized systems and will cause the symptoms you describe when used in a gravity feed system . Remove it and see if the bike runs better.
Valve adjustment is one of the most important parts of the regular maintenance and should be tended to right away. If the clearances are too small, the engine will run poorly and will eventually begin to suffer damage.
Last edit: 15 Jul 2023 21:10 by TexasKZ.
The following user(s) said Thank You: ellwinger
  • Nerdy
  • Nerdy's Avatar
  • Away
Re: Sprockets
16 Jul 2023 07:16
#887292
I'll check.
A helpful hint: when you reply to someone, use the Quote button so people know which post you're answering. The forum software doesn't arrange posts by threads, so when you say "I'll check" we have no idea what you're checking. :)
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
  • Nessism
  • Nessism's Avatar
