Sprockets
- ellwinger
Sprockets
11 Jul 2023 09:56
My KZ650H runs great but tops out at 55 mph and 4000 rpm. That seems like the rpms are WAY to high and it needs to be geared down. Am I wrong?
Re: Sprockets
11 Jul 2023 10:01
When you say it “tops out” what do you mean? Are you saying it won’t go anymore in any gear?
Re: Sprockets
11 Jul 2023 11:00
4000 rpm at 55 mph sounds about right. The engine is built to REV, so rev it and enjoy!
- ellwinger
Re: Sprockets
11 Jul 2023 12:25
Doesn't 55mph seem a little slow? It won't rev higher than that.
Re: Sprockets
11 Jul 2023 13:28
If it won't rev past 4000 then that is a totally different issue
- Nerdy
Re: Sprockets
11 Jul 2023 13:561967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- Nerdy
Re: Sprockets
11 Jul 2023 13:58If it won't rev past 4000 then that is a totally different issue
Could the ignition advancer be hanging up (i.e. not advancing)?
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- Injected
Re: Sprockets
11 Jul 2023 14:02A good running 650 four cylinder should "top out" at 110MPH @ 9000 RPM.My KZ650H runs great but tops out at 55 mph and 4000 rpm. That seems like the rpms are WAY to high and it needs to be geared down. Am I wrong?
1978 KZ650B2 modified project
The following user(s) said Thank You: ellwinger
Re: Sprockets
12 Jul 2023 08:44 - 13 Jul 2023 08:00
Assuming you have an 85mph speedometer, a 650-CSR should be able to peg the needle no problem with power to spare.
Make sure the battery is good and fully charged. I would do a load test.
Ignition coils. ride the motorcycle at speed, then stop & feel them. don't get burned by the valve cover.
The ignition coils should get warm, not hot. Mine were very hot to the touch, so I got new Dyna coils.
Clean, check & lubricate the timing advancer. make sure the springs & stuff are good and not rusted or damaged or anything.
Separate the rotor from the body while servicing & fill the groove w grease. Afterwards, operate the advancer by hand >> the rotor should snap back when released. This stuff is in the manual.
Last edit: 13 Jul 2023 08:00 by martin_csr.
Re: Sprockets
12 Jul 2023 08:47
Has all of the routine maintenance listed in the owner’s manual and the factory service manual been performed recently? If you are not 100% sure about any item on the list, I would start at the top and do each and every item as listed. In the process, you are quite likely to find the problem, and when you finish the list, you can be sure the bike is performing as designed. Following the schedule will insure that you have a well-running, reliable ride.
- ellwinger
- ellwinger
Re: Sprockets
14 Jul 2023 20:15
Everything checks out. Doesn't seem to be getting enough gas above55.
