1982(83?) KZ550 C
  • dthemac
  • dthemac's Avatar Topic Author
Re: 1982(83?) KZ550 C
14 Apr 2023 05:53
#883109
Thanks! I'll recheck later today. I assume the only way to know what shim is under the bucket is by removing it and checking?
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Apr 2023 05:59 - 14 Apr 2023 06:10
#883110
Correct, you can then use the chart in the manual to identify the correct size - from the picture it looks like the shims are on top of the buckets so with the right tool you can replace them with the cams in situ.
The cheapest way would be to measure them all, then remove the cams and measure the shims that you already have (if you are lucky you can move some around and reduce the amount of new ones required) You have to remove the cams to do this as you can't rotate them on the buckets once the shims are removed but you won't need any special tools to change the shims
Last edit: 14 Apr 2023 06:10 by Wookie58.
  • dthemac
14 Apr 2023 06:12
#883112
Wait really? I thought they were under the buckets on this engine.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Apr 2023 06:13 - 14 Apr 2023 06:21
#883113
I don't know for sure, just looks like they are on top in the picture
EDIT: looks like you are right, remember when removing the cams to slacked the retaining bolts evenly to avoid damage
Last edit: 14 Apr 2023 06:21 by Wookie58.
The following user(s) said Thank You: dthemac
  • TexasKZ
  • TexasKZ's Avatar
14 Apr 2023 06:25 - 14 Apr 2023 06:29
#883114
Here is a link to a bunch of info specific to the small fours, especially the 550. I recommend you download as much as you think you will ever need, as the author, Lou, died a couple of years ago, so there is no telling how much longer the site will be up.
​​​​​​https://s3.amazonaws.com/gpzweb/index.html
Also, the factory method of measuring the lash is a little more tedious, but will insure that there is equal spring pressure on each lobe being measured. If the cam bearings are really tight, the difference will be pretty small, but if they have a little wear, there will be a measurable difference in the measurements between the factory method and just pointing each cam lobe straight up.
Last edit: 14 Apr 2023 06:29 by TexasKZ.
The following user(s) said Thank You: dthemac, Wookie58
  • dthemac
14 Apr 2023 06:27
#883115
Yeah it looks like it's under bucket, so I'll have to pull the cams. Are shims something I have to order or can they be had from like a cycle gear?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
14 Apr 2023 06:27
#883116
....and don´t forget to reset the cam chain tensioner before you put the cam cover back on top.
s3.amazonaws.com/gpzweb/CamsKZZXZR550500...KZZXZR550500400.html
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Apr 2023 06:30
#883118
I'm not sure, maybe another member in your part of the world can best advise (where are you?)
  • dthemac
14 Apr 2023 06:31
#883119
Much appreciated!
  • dthemac
14 Apr 2023 06:31
#883120
I'm in Southwest Ohio.
  • TexasKZ
  • TexasKZ's Avatar
14 Apr 2023 06:34
#883121
You may be able to swap some of them around to different positions and reduce the number of replacement shims you need. If there is a dealership nearby, the shop may be willing to sell you the shims you need, or if you are really luck, may be willing to swap them.
  • dthemac
14 Apr 2023 08:39 - 14 Apr 2023 08:48
#883135
This line in the FSM is what is throwing me off. Does this mean that there should be two lobes in position to measure when at TDC?
Last edit: 14 Apr 2023 08:48 by dthemac.
