Compression issues
- jpacewic
Compression issues
26 Mar 2023 14:06
Hello again. 1981 kz1000 csr. I had the bike running good. Then it started running rough again. I pulled the number one plug and installed gage. I could only get 90 psi while turning it over. Dumped a little oil in the cylinder and got about 140 psi. I am assuming the rings are shot. Can I do this repair with the engine in the frame? Should I do a full rebuild? Any advice would be greatly appreciated.
- ckahleer
Re: Compression issues
26 Mar 2023 14:55
Did you remove all plugs and hold the throttle wide open when checking compression? If not, warm the engine up good and check compression again, before tearing the engine down.
97 ZL600
94 VF750c
94 KE100
82 KZ305
94 VF750c
94 KE100
82 KZ305
26 Mar 2023 14:55
The answer to your first question is yes, you can do cylinder repairs without pulling the engine from the frame. Whether you should do a full rebuild depends on a lot of factors, including your financial situation, your expertise and other issues, if any with the bike. It's a personal choice, but if it were me I would probably pull the engine and do a complete inspection, replace any worn parts including the timing chain and put it back to together.
- jpacewic
20 Apr 2023 22:28
I think the best way to go for me is to replace the pistons and rings. Now the question is do I go with stock size or bore it out a little? What is the process? I have read about sleeves. What is the safe way to go? Again, thank you for all the help.
21 Apr 2023 03:26
A leak down test will tell you the truth about your missing compression.
21 Apr 2023 05:26
If you have a service manual it will have tolerances on pistons, cylinders, valves etc. My guess is that your pistons may be OK but you may need to replace rings and hone the cylinders before rebuilding the engine. If the cylinders are worn beyond tolerance you can bore them slightly to what is called first oversize. In that case you will need new pistons and rings to match.
21 Apr 2023 06:57
There is not enough information to make an informed decision regarding the plan of action. For example, as mentioned already, was the engine warm and the throttle held open when performing the compression test? Have you kept up with valve adjustments on the engine, and are all the clearances currently in spec? How many miles on the engine? What specifically is the bike doing when you say it's running rough? Is it firing on all cylinders? Did you check spark on all cylinders? Does the engine burn oil? Foul plugs? Is the gas tank free from rust and debris? How long since the carbs were rebuilt?
- jpacewic
21 Apr 2023 12:04
Where can I find the procedure for the leak down test?
- jpacewic
21 Apr 2023 12:07
The engine was warm and the throttle held wide open. The compression on the #1 cylinder was very low. Then as per the Clymer manual, I poured some oil in the cylinder and the compression came up to 130 psi.
- jpacewic
21 Apr 2023 14:13
The leak down test show you, (you can listen and hear), where the compression pressure escape on TDC.
It could be escape over the piston rings (engine vent, oil fill cap).
It could be escape over the IN or EX valve port site due to carbon build up on the valve seat and head seat ring surface.
Dump the Clymer manual into the bin please!
- Injected
21 Apr 2023 14:17
1978 KZ650B2 modified project
The following user(s) said Thank You: Scirocco
