Compression issues
- Nebr_Rex
Re: Compression issues
21 Apr 2023 20:41I apologize 140 psi.
Rings are shot.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- F64
- 81-KZ440D2
22 Apr 2023 08:49 - 22 Apr 2023 11:34
You can do the listening part of the leak down test without the gauge.
You just need an air compressor and a spark plug adapter(usually you can use the hose for the compression tester if it has a quick connect fitting).
Just make sure you are at top dead center on the cylinder otherwise when you apply air pressure the engine will spin.
You want to listen to where the air is escaping(air intake, oil filler opening, exhaust pipe, pvc)
You won't be able to quantify the amount of your leak but you may be able to locate the source of the leak(s).
I made a leak down tester following Mike Nixon's instructions
www.motorcycleproject.com/text/Leakdown.html
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 22 Apr 2023 11:34 by F64.
