KZ400 Cold malfunction
- Feanor_twh
27 Feb 2023 15:04 - 27 Feb 2023 15:08
My KZ400 starts fine (if it's very cold you need choke) but for about the first 15 minutes of riding I have to keep the throttle half open otherwise the engine stalls. Once it has warmed up, it works perfectly, totally stable idling. But if I let it stand still for a while the engine cools down and when starts tends to stall until it warms up again.
I have not given it much importance because I thought it was normal (I restored the bike 3,000 miles ago and I don't know how it worked before this), and because it is also a good way of know if the engine is hot and ready to rev up. But almost everyone talks about "30 seconds on choke, then remove and voila, stable idling, ready to run".
Does anyone know anything about this or has it ever happened to them?
(1976) Kawasaki KZ400-D3. All original, but: electronic reg/rec (Oregon Motorcycle Parts), new handlebar controls (w/ PASS/HORN/lights switch, LED dash lights (superbrightleds.com), Dynatek coil (3ohm), MAC mufflers, HEL brake hoses, rubber fork boots, 4.00 rear tyre (Dunlop K70), chromed chainguard
Last edit: 27 Feb 2023 15:08 by Feanor_twh.
- F64
- 81-KZ440D2
Re: KZ400 Cold malfunction
27 Feb 2023 15:46 - 27 Feb 2023 16:49
Engine should be hot enough to vaporize the fuel.
I feel the engine cooling fins with my hand.
When the fins near the carbs are warm/hot, the bike is ready.
Your times will vary each time you start the bike.
Others will tell you their methods.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 27 Feb 2023 16:49 by F64.
The following user(s) said Thank You: ThatGPzGuy, Feanor_twh
27 Feb 2023 19:49
It shouldn't take 15 minutes of running before the bike will run without choke. More like 5 minutes.
Where are the pilot screws set? Is the bikes intake system stock? Airbox installed with a proper air filter?
- Feanor_twh
28 Feb 2023 01:28 - 28 Feb 2023 01:35
I only use the choke for starting, for about ten seconds, then continue to open throttle so it doesn't stall.
One turn on pilot screws, both carburettors. Intake system stock. I have to check the filter but I think I put the right one.
Last edit: 28 Feb 2023 01:35 by Feanor_twh.
28 Feb 2023 04:52
1 turn out on the pilot screws is not enough. Try 2.5 and see if the bike runs better. And don't be afraid to run the bike on choke longer. That's what it's for.
The following user(s) said Thank You: JR, Wookie58
- Feanor_twh
28 Feb 2023 06:21 - 28 Feb 2023 06:22
Thanks, I'll try with the pilot screw.
I'm also going to investigate how to make the choke non all-or-nothing, as I observe that it is sometimes more useful somewhere in the middle but tends to go up itself.
Last edit: 28 Feb 2023 06:22 by Feanor_twh.
