What is your technique for CLEANING FOULED spark plugs
  • DanMadBoy
  • DanMadBoy's Avatar Topic Author
  • Banned
  • Banned
03 Feb 2023 07:06
#879717
Kz650. Using NGK BR7ES. .
What is your technique for cleaning fouled spark plugs.
  • Warren3200gt
  • Warren3200gt's Avatar
Re: What is your technique for CLEANING FOULED spark plugs
03 Feb 2023 07:13
#879718
Oil fouled need to be torch burned off. Carbon fouled just need wire brush clean.
  • DanMadBoy
  • Banned
  • Banned
03 Feb 2023 07:14
#879719
Thanks. Cant they ever get wet and then dried out, like if I wanted to clean them in Simple Green?
  • Buzz Nichols
  • Buzz Nichols's Avatar
03 Feb 2023 07:14
#879720
Personally, I usually use 220 grit sandpaper, but that's mostly because I've always got plenty of that on hand.
1978 KZ1000 LTD
  • Warren3200gt
03 Feb 2023 07:15
#879721
If your using br7es resistor plugs make sure your using non resistor plug cap.
You can only have one resistor in the circuit or it'll run like crap.
  • 78kawltd
  • 78kawltd's Avatar
  • 1978 B2, 06 Heritage Softail,
03 Feb 2023 07:17 - 03 Feb 2023 07:24
#879722
I have successfully used a soaking in some carb cleaner with a soft metal bristle brush follow up.  Finish with a lite paper sanding ( 220 grit ) at the tips. Try that to remove your carbon.  And yes, finish with a soft cloth to wipe off any potential residue.
Last edit: 03 Feb 2023 07:24 by 78kawltd. Reason: clarification
  • Warren3200gt
03 Feb 2023 07:20 - 03 Feb 2023 07:23
#879723
That's really not a good idea if you actually mean SAND paper and it's not an American v English terminology. You'll score your bores to bits if you accidentally leave any bits of residue in/on the plug.
Last edit: 03 Feb 2023 07:23 by Warren3200gt.
  • DanMadBoy
  • Banned
  • Banned
03 Feb 2023 07:22 - 03 Feb 2023 07:26
#879724
Warren, in re the resistor, forgive me for my ignorance, but what do you mean? that little bulb on the end of the spark plug? I take that off so the screw is exposed and it plugs right into the boot.
In re the rubber caps, not sure they are non - resistor. I have the red wires that go with the aftermarket coils dyna everyone raves about. They are green.
Last edit: 03 Feb 2023 07:26 by DanMadBoy.
  • Warren3200gt
03 Feb 2023 07:28
#879725
No mate. In br7es plugs the R stands for resistor. It's actually built into the plug. So if your using br7es plugs you can't use a plug cap that has a resistor built into also. Two resistors in the line will severely impead your spark performance and........... foul your plugs.
You want either a resistor plug or a resistor cap but not both or no resistors at all.
  • F64
  • F64's Avatar
  • 81-KZ440D2
03 Feb 2023 07:29
#879726
Just clean it like Warren said with the torch.
Your engine keeps them clean by keeping the ceramic nose between 450°C 842°F----800°C 1472°F
81-KZ440-D2.
LIC, NY
The following user(s) said Thank You: Warren3200gt
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
03 Feb 2023 07:38
#879728
If you want to brush them up after burning (or in place of) there are specific brass brushes cheaply available specifically for this purpose
The following user(s) said Thank You: Warren3200gt, 78kawltd
  • Mikaw
  • Mikaw's Avatar
03 Feb 2023 08:02
#879730
I agree and have used a propane torch. Takes some time so don’t have dinner warming up. The trick is to get the flame to swirl around the porcelain and get to bottom where the porcelain and steel meet.
