- Thank you received: 35
am I correct, the valve doesn't rotate generally?
- Gdailey2112
- 82 KZ1100D1
06 Oct 2022 11:39 #875176
by Gdailey2112
1982 KZ1100D1
Replied by Gdailey2112 on topic am I correct, the valve doesn't rotate generally?
right on Jeff!! that is what i'm lookin for.
great responses from all, thank you
1982 KZ1100D1
- DFIGPZ
- Thank you received: 122
06 Oct 2022 16:08 - 08 Oct 2022 12:39 #875186
by DFIGPZ
Is Correct cam is not centered on valve so some rotation should be expected
1984 750 Turbo
Replied by DFIGPZ on topic am I correct, the valve doesn't rotate generally?
JeffThe cam lobe is not centered on the bucket/shim, so there is a little rotational force going on. The offset is to spread the wear on the shim/bucket.]
1984 750 Turbo
Last edit: 08 Oct 2022 12:39 by KZQ.
The following user(s) said Thank You: Gdailey2112
- Gdailey2112
- 82 KZ1100D1
09 Oct 2022 14:37 #875298
by Gdailey2112
1982 KZ1100D1
just something that had me wondering
to me, you fellas are some of the most absolutely knowledgeable gurus, i'm jvery grateful
1982 KZ1100D1
