Slipping clutch low gears high rpms
  • xstreamcanadian
  • xstreamcanadian's Avatar Topic Author
20 Jun 2022 20:52
#869146
Took my 78 650 on its maiden test ride. The clutch plates and springs are new, as is the cable. It's slipping at higher rpm and lever wise it seems to engage in a weird spot. The cable is tight, I've adjusted the screw in bolt according to the manual, tight then minus a quarter turn..... thoughts? Ive read that the new discs need to get oily before they start working properly. It's been ridden a total of 500m or so. Too soon?
  • Injected
  • Injected's Avatar
Re: Slipping clutch low gears high rpms
20 Jun 2022 22:54
#869149
What are you using for oil? You can't use car oil in these engines as it has too many "slip" additives for these clutches.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
  • zed1015
  • zed1015's Avatar
  • Away
20 Jun 2022 23:26 - 21 Jun 2022 01:21
#869151
It's possible the clutch isn't adjusted correctly and as suggested the oil should be jaso spec for wet clutch's.
The new plates should also have at least been oiled if not soaked in the same oil prior to install as running from dry can glaze or burn out the friction plates quickly causing the slip you describe.
You problem of engagement point and slipping could be one or more of the above three.
Last edit: 21 Jun 2022 01:21 by zed1015.
  • xstreamcanadian
21 Jun 2022 07:22
#869161
I did soak them. What oil does everyone use? I used a dino oil, that I recall was reccomended from someone on here. I dont recall it being a motorcycle specifc oil though
  • xstreamcanadian
21 Jun 2022 07:29
#869162
I also wonder if I didnt back off the adjustment screw enough, or made it too tight.
  • xstreamcanadian
21 Jun 2022 07:43
#869163
i used castrol 10w30 dino oil i think. Ive read that if it has a green energy symbol on it, it can cause slippage
  • Mikaw
  • Mikaw's Avatar
21 Jun 2022 08:13 - 21 Jun 2022 13:17
#869164
If you have the empty bottles look for a JASO/ma rating. Or it will say for wet clutch systems. I wouldn’t run the bike till you sort out the oil.
Last edit: 21 Jun 2022 13:17 by Mikaw.
The following user(s) said Thank You: xstreamcanadian
  • zed1015
  • zed1015's Avatar
  • Away
21 Jun 2022 08:37
#869165
You only need to run the adjuster screw up lightly until you feel it touch against the pushrod.
No need to actually tighten it before backing off.
The 1/4 turn back and leaving 1/8th" slack on the cable at the lever is to allow for heat expansion of the lifter components when hot to avoid the clutch slipping.
The following user(s) said Thank You: xstreamcanadian, Scirocco
  • xstreamcanadian
21 Jun 2022 11:38
#869179
So good news. I slacked the the clutch cable, and reset the screw adjustment while it was cold(apparently this is key also) , checked the oil, it is 10w40 non 'green' oil. so I took her out for a rip, 20 kms or so, and the slipping is gone. I also read that the new discs and new springs etc will pretty much also slip and act weird for the first 100km or so. so people say anyway
  • xstreamcanadian
21 Jun 2022 11:39
#869180
it is 10w40 dino oil. So its good. Wasnt the issue after all see the above post
cheers
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
21 Jun 2022 11:59 - 21 Jun 2022 14:11
#869182
Dino oil only means so much.
Most car and truck oils for modern vehicles  have additives  that are not meant for your bike . ( Super slippery )
Remember that the bike has a common oil system for the motor, transmission , and clutch
Car motors are motor only  so the additives help out
The additives make the clutch TO  slippery.
A safe oil commonly used by a large part of this KZ community is Shell Rotella Diesel oil
Ther must be more threads on this subject here at KZR than I can count
Good Luck
Last edit: 21 Jun 2022 14:11 by Street Fighter LTD.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
21 Jun 2022 13:27
#869185
Cars,Suv and vans running a dry clutch = not the same oil in the transmisson.
Bike do share the same oil in the engine and transmission (wet clutch) = JASO RATING = NO ANTI FRICTION ADDITIVE !!!
