Low compression
- gtrain
Low compression
13 May 2022 17:24
Hi all I have a problem with my z1000st I had it bored to 1100 fitted a set of cruise image pistons and rings, now its hard to start doesn't idle well, I've check valve clearances check valve seats, carried out a leak down test,but compression is around 120psi across all four cylinders remove the head again and noticed that at individual top dead centres the pistons don't go to the top of the cylinder, heres a picture is this normal?
Any advice would be appreciated.
- Nebr_Rex
Re: Low compression
13 May 2022 19:45
Most engines run with a positive piston deck height [below the top of the cylinder block].
How thick is your base gasket? Have you considered using no base gasket just sealer?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
Re: Low compression
14 May 2022 02:24 - 14 May 2022 02:49
To be honest if you have 120psi on a freshly bored cold motor I think your problem probably lies elsewhere. Is the cam timing correct ?
PS: are the ring end gaps equally spaced 120 degrees apart ?
Last edit: 14 May 2022 02:49 by Wookie58.
- Warren3200gt
Re: Low compression
14 May 2022 03:01 - 14 May 2022 04:50
You don't say if that 120psi is hot or cold engine or throttle open or closed.
If that's cold then it's not too bad.
If that's throttle closed it's bloody brilliant.
Last edit: 14 May 2022 04:50 by Warren3200gt.
- blipco
- 2002 KZ1000P
Re: Low compression
14 May 2022 07:43
What type of compression tester? The type with a rubber end that you push on? Or a hose type?
If its hose type does it have a Schrader valve on the threaded end?, If not it'll read low as the hose adds volume to the combustion chamber.
- 750 R1
Re: Low compression
14 May 2022 15:50
Am I the only one that's seeing small bits of alloy around the edge of the piston ? I hope that was all cleaned out...
The following user(s) said Thank You: Nessism, Street Fighter LTD
Re: Low compression
14 May 2022 16:58
Also not mentioned is how much breakin was done to seat the rings after motor was built
Re: Low compression
14 May 2022 17:00Am I the only one that's seeing small bits of alloy around the edge of the piston
I saw that too but hoped that was small debris from pulling the head back off ( Hope , hope , hoping )
Re: Low compression
14 May 2022 18:02My guess was gasket material.
Re: Low compression
15 May 2022 00:39Look's like gasket scrapings to me but I have old eye'sAm I the only one that's seeing small bits of alloy around the edge of the piston ? I hope that was all cleaned out...
Re: Low compression
15 May 2022 04:42
With stock pistons the perimeter of the piston should just reach the top of the cylinder. So what you're showing in the photo is not normal, but those are not stock pistons if you bored to 1100. That said, 120 psi is a good reading, maybe a tad on the low side, but more importantly they are all within 15 psi of each other so it seems that your rebuild is OK.
As far as poor idle is concerned, what changes were made to your fuel and air circuits?
- blipco
- 2002 KZ1000P
Re: Low compression
15 May 2022 07:34
Isn't it true that the piston crown height is lower on an aftermarket piston to allow for planing the head?
