Suzuki exhaust gasket?
  • gordone
  • gordone's Avatar Topic Author
14 Dec 2021 10:38
#859069
I need new exhaust gasket and remember someone advise to use Suzuki gasket because the was thicker and easier to get it air tight.
Do I remember correct? Do you know the part number?
thank you
Project:
The following user(s) said Thank You: BostonBob
  • Highway Magician
  • Highway Magician's Avatar
Re: Suzuki exhaust gasket?
14 Dec 2021 10:45
#859070
14181-05020
Motorcycle builder since 1973. Master Tech. Current bike: 1982 GPZ1100B2.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
14 Dec 2021 11:57 - 14 Dec 2021 12:23
#859072
Just ordered another set of those yesterday...
Ebay item 401309439864 (10 pack).
It helps to spray a light coat of repositionable contact adhesive on one side before sticking them to the head so they don't move.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 14 Dec 2021 12:23 by daveo.
  • gordone
23 Jan 2022 06:48 - 23 Jan 2022 06:49
#860915
These K&L has some quality as OEM? No risk of leaks etc... ?
K&L Supply - 16-6063 - Exhaust Pipe Gasket For Suzuki 14181-05020 32x42x5.0mm
They was way cheaper !
Project:
Last edit: 23 Jan 2022 06:49 by gordone.
  • H1Vindicator
  • H1Vindicator's Avatar
23 Jan 2022 09:36 - 23 Jan 2022 09:37
#860931
Those K&L gaskets are Made in Japan. So they will be good quality. Make sure they are the correct size.
Last edit: 23 Jan 2022 09:37 by H1Vindicator.
  • SWest
  • SWest's Avatar
  • 10 22 2014
23 Jan 2022 15:00
#860948
One time use only. I won't buy again.
  • ckahleer
  • ckahleer's Avatar
23 Jan 2022 20:37
#860971
Please explain. I thought all exhaust gaskets are one time use. Are the copper ring type reusable?
97 ZL600
94 VF750c
94 KE100
82 KZ305
  • gordone
24 Jan 2022 00:29
#860978
K&L Supply - 16-6063 - Exhaust Pipe Gasket For Suzuki 14181-05020 32x42x5.0mmIs these correct size for my GPz750 head ?
Project:
  • H1Vindicator
24 Jan 2022 05:31 - 24 Jan 2022 05:41
#860986
OEM Suzuki gaskets might be reusable once or twice. ???  I'd be surprised if they can be reused more than that.  If they seal properly, I certainly wouldn't complain if they're single use. some guys don't like aftermarket but I've never had an issue w K&L parts.
Last edit: 24 Jan 2022 05:41 by H1Vindicator.
  • gordone
24 Jan 2022 06:53 - 24 Jan 2022 06:53
#860991
When it comes to size, these K&L gasket is listed to size:
32x42x5.0mm
z1enterprises list OEM replacmeent gasket
To size:
31 x 39.4 x 2.8mm
OEM:
www.partzilla.com/product/kawasaki/11009...472b607db30284563d39
Will the K&L 32x42x5.0mm fit... they are bigger ?
Project:
Last edit: 24 Jan 2022 06:53 by gordone.
  • Rick H.
  • Rick H.'s Avatar
24 Jan 2022 07:20
#860992
I tried the Suzuki exhaust gaskets on my KZ-1000 but they were too thick.  Unfortunately, I wasn't able to start the nuts on the exhaust studs.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
24 Jan 2022 07:29 - 24 Jan 2022 08:23
#860993
32x42x5.0mm
To size:
31 x 39.4 x 2.8mm
OEM:
Correct!
www.z1enterprises.com/copper-exhaust-gas...%2Fall-models%2F1981
Perhaps this one would fit better:
www.z1enterprises.com/exhaust-gasket.html
Or perhaps a 10-pack of the same for cheap:
Ebay item 143576808780
Last edit: 24 Jan 2022 08:23 by daveo.
