Z1R Spat out a Shim
- zed1015
Re: Z1R Spat out a Shim
12 Dec 2021 08:20 - 12 Dec 2021 08:43Here in the UK ( and everywhere else i know of ) a Dimple is an indent not a raised area.
Early shims had an indent that resulted in a stress area which were prone to breaking and were replaced with the plain shims.
Last edit: 12 Dec 2021 08:43 by zed1015.
12 Dec 2021 08:31
No idea if this could be related but K&L made a bunch of bad shims a while back. Z1 stopped selling them at one point. This was for Suzki GS shims though, not sure if KZ shims were likewise affected.
- slmjim+Z1BEBE
12 Dec 2021 14:00The bulletin we mentioned shown below:Here in the UK ( and everywhere else i know of ) a Dimple is an indent not a raised area.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Dragbike_Mike, krazee1
- larriken
13 Dec 2021 12:03Thanks for the info! Really interesting and look what I found after I pulled all the shims out.......The bulletin we mentioned shown below:Here in the UK ( and everywhere else i know of ) a Dimple is an indent not a raised area.
Good Ridin'
slmjim & Z1BEBE
- larriken
13 Dec 2021 12:15
Last night I took the clearance measurements and then pulled the shims and measured all of them. This is what I have;
There is an assortment of shims used and only one still has the numbers visible on it. The one in the photo below looked a bit odd too.
- larriken
13 Dec 2021 12:17Please Log in or Create an account to join the conversation.
- zed1015
13 Dec 2021 12:55 - 13 Dec 2021 15:07That shim has been ground (badly) and the lower one in the other pic has been messed with too.
Your "Experienced Kawasaki guy" needs sacking and you should go through that engine to closely inspect anything he has touched before it's run again.
Last edit: 13 Dec 2021 15:07 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE, Street Fighter LTD, SWest
13 Dec 2021 16:30
From the looks of those shims I suspect the broken one was ground. A further guess....your valve stems were also ground. All of those shims are on the thin edge of the range. One of them is at the very bottom. (2.00)
Zed1015's comment about sacking brings back a memory of a line in the Beatles' song "Piggies"..."What they need's a damn good whacking!" I totally agree with 1015. Anything this guy touched should be reviewed.
13 Dec 2021 17:58HRM, good eye. Look at the valve tip. It shows the same grind marks as on the shim.From the looks of those shims I suspect the broken one was ground. A further guess....your valve stems were also ground.
13 Dec 2021 18:07
I was thinking the keepers were touching the lifter but it does look like the valve stem had been tipped. NOT GOOD
13 Dec 2021 18:40 - 13 Dec 2021 18:43I was thinking the keepers were touching the lifter but it does look like the valve stem had been tipped. NOT GOOD
Yes, AND the shims are at the low end of the range. Now I'm wondering if he did the seats and over cut them? Then tipped the valves and ground some shims. I'm willing to bet if you measure those ground shims that they are less than 2.00.
Last edit: 13 Dec 2021 18:43 by hardrockminer.
13 Dec 2021 18:51
