Valve-Lash Affect On Cylinder Compression
- daveo
- Warren3200gt
Re: Valve-Lash Affect On Cylinder Compression
08 Dec 2021 06:52 - 08 Dec 2021 06:59
Valve lash can affect compression readings if it's tight and not closing the valve fully. If the valve seats are worn or dirty that will also affect compression.
Can you use valve lash to dilliberately equalise compression between cylinders? In a word no.
Upto 10% difference is acceptable and fairly normal.
Especially the middle cylinders being lower values as they run hotter than 1 & 4.
If you have more than that then you need to investigate why. Could be worn or broken ring/s. Worn or Scratched bore/s, Gasket leak or a number of other reasons.
Last edit: 08 Dec 2021 06:59 by Warren3200gt.
- zed1015
08 Dec 2021 08:21No.
The following user(s) said Thank You: Nessism, daveo
- daveo
08 Dec 2021 08:24 - 08 Dec 2021 08:54
Had a professional valve job done, and the head was installed last week. Compression was checked immediately after the first run and carb sync. Weather permitting, I'll check valve-lash and compression again after a good-long ride this weekend.
Now that I think about it, the perfect opportunity to have combustion chamber volumes measured was while the head was out for service...
1982 KZ1100-A2
Last edit: 08 Dec 2021 08:54 by daveo.
08 Dec 2021 08:29
It will take time for the rings/valves to seat in. May not happen if the engine is running cold.
- zed1015
08 Dec 2021 08:35
If everything checks out valve clearance wise and the bike goes well i wouldn't worry about comp figures and just ride it..
- daveo
08 Dec 2021 09:58Yessir, that makes sense. Just gotta be patient and get some riding time in. My current local weather forecast shows 50's for next week.It will take time for the rings/valves to seat in. May not happen if the engine is running cold.
1982 KZ1100-A2
- daveo
08 Dec 2021 10:04If everything checks out valve clearance wise and the bike goes well i wouldn't worry about comp figures and just ride it..
Advice greatly appreciated, always!
1982 KZ1100-A2
- F64
- 81-KZ440D2
09 Dec 2021 10:14 - 09 Dec 2021 10:28
What are the numbers?
Plus this is just static compression. Your dynamic compression may be much different.
Which means your engine may behave differently once it starts running and breathing at speed as opposed to a static measurement prediction.
81-KZ440-D2.
LIC, NY
LIC, NY
Last edit: 09 Dec 2021 10:28 by F64.
09 Dec 2021 16:32Can I pile on and say HELL NO!
Break in the rings firmly, but not harshly. Drive the bike assertively around town. Don't baby it. Use a good handful of throttle but don't thrash the engine until you get up to a few hundred miles or so. After that, let'er RIP! (or to quote Steve: drive the shit out of it!)
09 Dec 2021 18:32
- daveo
13 Dec 2021 14:26140, 130, 140, 140 readings taken 12/13/21 with engine hot immediately after a 100 mile ride, 330 miles after head was installedWhat are the numbers?
1982 KZ1100-A2
