Head hot enough to boil oil?
- rokit_armor
13 Oct 2021 09:41
After a quick ride home yesterday from work (~2 miles) the top end on my bike was quite hot- I could hear boiling/popping sounds from inside. I've got my timing dialed in, and carbs jetted (a hair on the rich side) so I'm pretty sure it's not running hot due to a lean condition. Would the oil pressure from a stock pump be enough to cool a hot street build, or should I invest in an oil cooler? Is there a high-flow/pressure oil pump available as well?
Re: Head hot enough to boil oil?
13 Oct 2021 16:43
Most of the late KZ bikes ran an oil cooler. That doesn't mean they are necessary though. I'm not sure about the shaft drive 1100 but with a lot of KZ engines you can install a later oil sump cover pan with the oil cooler takeoffs built in which makes installing a cooler easier. That's what I did with my 750 anyway. If you just ride your bike around in a sane fashion I'd skip the cooler. As a mitigation against overheat abuse you can run synthetic oil which has a much higher vapor temperature compared to mineral oil.
- rokit_armor
13 Oct 2021 18:37Well that's just out of the questionIf you just ride your bike around in a sane fashion
I just changed the oil with some Liqui-Moly 4T 15w50, I don't think its syntheic.
I'll see about the sump cover pan, finding a GPZ takeoff is turning into an expensive endeavor.
- z1kzonly
14 Oct 2021 03:50
If your head is boiling oil? Something is too tight in that valve train!
14 Oct 2021 06:00
I think I would get an infrared thermometer and find out for sure if something is getting too hot, and if so, what, before I began randomly replacing parts.
- daveo
14 Oct 2021 07:17 - 14 Oct 2021 09:30
Do BS34 carbs provide adequate air/fuel flow for an 1170 engine with high lift cams?
RS36's+ would on my Christmas list.
1982 KZ1100-A2/1170 sleeper 😀
Last edit: 14 Oct 2021 09:30 by daveo.
- DOHC
- Those Doe-Hawks really go!
14 Oct 2021 08:05I think I would get an infrared thermometer and find out for sure if something is getting too hot, and if so, what, before I began randomly replacing parts.
This is very good advice. Harbor freight sells one for $25.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- rokit_armor
14 Oct 2021 20:14They do seem to! I would not mind some RS36s, that would be a few Christmases worth though.
- rokit_armor
