Starter clutch removal
Re: Starter clutch removal
03 Sep 2021 06:01 - 03 Sep 2021 06:02It will look like this.When replying to a specific post, especially in a thread that several people are posting in, it is a good idea to click the QUOTE button instead of the REPLY button. When you do that you will see the quoted post at the top of the window. Click or tap well below the quotation, and a red dashed line will appear. Near the right margin, there will be a left-pointing arrow. Click it so that your cursor jumps down below the line, and begin typing there. This will insure that your reply is visually separated from the quoted material and what you are responding to will be clear to everybody else.
Last edit: 03 Sep 2021 06:02 by TexasKZ.
The following user(s) said Thank You: Cfoux85
- hugo
- '92 Zephyr 750
03 Sep 2021 16:54Fixed it for you.I know.....am so stupid.Thanks for the tip!
- riturbo
04 Sep 2021 06:23
So im still confused . Does it sound like marbles or does nothing happen when you push the button ?
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- Cfoux85
- 1982 Kawasaki kz 750e
05 Sep 2021 15:37
It would turn over, then I had an issue that when I pushed the start button I would hear a single click. I replaced the solenoid and it would try to crank like normal. Now it sounds like chains dragging or something or like a grinding noise
