How f***** am I?
  • 1980 Z1R D3
  • 1980 Z1R D3's Avatar Topic Author
  • A young gun with a taste for two-wheeled fun!
Re: How f***** am I?
28 Dec 2025 08:04
#920120
Hi guys,
I am going to attempt to revive this thread as this summer my head gasket leak has gotten bad enough again that I can justify taking the head off again... it'll only be the third time I've done it in six years!
I am starting to suspect that the head is warped because new gaskets only seem to slow the leak until it gets worse again, btu that will be a problem for when I get it off.
I figured if thats gonna happen I might as well replace the two idler gears, the roller and the timing chain guide while I am in there. A long time ago, I found a fella who was making solid metal idler gears to replace the exorbitantly expensive NOS ones with the rubber in them. A precursory google search yielded nothing, so was hoping you guys might be able to point me in the right direction and jog my memory a bit.
1980 Z1R D3
  • zed1015
  • zed1015's Avatar
28 Dec 2025 09:25
#920122
Whatever you do DO NOT have the head skimmed until you have checked that the cams will spin free when bolted back in the head on the bench with the valves etc removed .
Some of these heads develop a slight twist in their free state which straightens out once bolted back on.
If one of these "twisted" heads is skimmed the twist will remain in the cam journals when the head is refitted which will cause the cams to bind and destroy the shells etc.
The following user(s) said Thank You: slmjim+Z1BEBE, MFP-Joe, Dragbike_Mike, Wookie58
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
28 Dec 2025 16:38 - 28 Dec 2025 18:39
#920133
Not one leak since!
1982 KZ1100-A2/1170cc sleeper 😀
Last edit: 28 Dec 2025 18:39 by daveo.
The following user(s) said Thank You: SWest, 1980 Z1R D3
  • sf4t7
  • sf4t7's Avatar
28 Dec 2025 17:16 - 28 Dec 2025 17:19
#920136
You can still find the Liska style sprockets, tensioner, and top idler at KZZone.  The front guide looks to still be available from Z1Enterprises.
Retro-motorcycles on Ebay has the front cam chain guide,small rubber damper blocks for the sprockets and for the lower roller.  KZZone has a handy diagram for reference.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
Last edit: 28 Dec 2025 17:19 by sf4t7.
The following user(s) said Thank You: MFP-Joe, 1980 Z1R D3
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Online
29 Dec 2025 04:11
#920147
Very interesting observation.
Mama Kaw specs a test in the Z1 White Manual for "warp" (less than .25mm / 0.010 in.) with the suggestion to replace the head if warp exceeds the service limit.  Uh huh...
If a head was determined to have a warp / twist in its free state, does that mean it's not a candidate to be skimmed?  If skimming is possible, how would the machinist set up or jig the head?  Are the cams stiff enough to straighten the head sufficiently for skimming if they're bolted into their positions?
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • zed1015
  • zed1015's Avatar
29 Dec 2025 09:20 - 29 Dec 2025 15:40
#920154
Good Ridin'
slmjim & Z1BEBE
The manual suggests replacing a warped head for the same reason.
If the head is warped then so is the cam journal alignment so they don't even mention skimming because the warp will remain in the journals.
The cams won't pull the head straight or rectify the twist though.
To skim one it would have to be bolted down on a thick precision ground steel fixture plate to pull it straight.
At a guess the plate would have to be a couple of inch thick and utilise all of the 32 m6 holes for the cam cover and cam caps which should be enough to do the job.
I've often thought of making a jig for this job to see if it would work but the cost of the plate alone was in the high hundreds and buying replacement heads was a cheaper option.
Last edit: 29 Dec 2025 15:40 by zed1015.
The following user(s) said Thank You: slmjim+Z1BEBE, sf4t7
  • 1980 Z1R D3
01 Jan 2026 12:22
#920251
Thanks for all the help Gents!
I will def look into those head studs...I'm sure removing the old ones would be fun!
The liska parts will be my go to for this job.
Very interesting on the head skimming point zed1015, that plate sure sounds like it could make skimming possible, but I am no machinist. I'd sure hate to have to replace the whole head...tho it would make a cool conversation piece!
1980 Z1R D3
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
02 Jan 2026 06:59
#920263
MBS1000K
Ebay
 # 3894319 44136
is currently available for a decent price if used is acceptable.
My .02 cent suggestion is replace the old studs, and find another head if it doesn't solve the problem.
  • SWest
  • SWest's Avatar
  • 10 22 2014
02 Jan 2026 08:25
#920265
I replaced all of them. There's a certain security in knowing what's going on between your legs.
  • Michi
  • Michi's Avatar
02 Jan 2026 09:40
#920268
Just curious, but are the plain sections on the studs slightly narrower than the threads, on either the old or the new set?
KZ440A LTD (1980)
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
02 Jan 2026 14:11
#920274
Shaft diameter comparison
