Oil pan "crack" would you run this?
- idmurp
03 Jul 2021 07:02
Bottom end was built before I got the bike. Filled it with oil and had a leak from the gasket where the bolt had caught it. When changing it have spotted this. Would you run it or replace? Its never been run with this so dont know if it leaks.
1992 KZ1000p in pieces
- DOHC
- Those Doe-Hawks really go!
Re: Oil pan "crack" would you run this?
03 Jul 2021 07:10 - 03 Jul 2021 07:56
I can't be sure, but those don't look like cracks to me. It looks like surface imperfections left over from the molding/casting process. You can find lots of those lines on all of the cast aluminum parts on these engines.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 03 Jul 2021 07:56 by DOHC.
The following user(s) said Thank You: idmurp
- idmurp
03 Jul 2021 07:16
That was my first thought, but they have corresponding marks on inside and outside that make me think cracks
03 Jul 2021 07:28
CASTING FLAWS DON'T WORRY ABOUT IT
The following user(s) said Thank You: Nessism, idmurp
- idmurp
03 Jul 2021 07:36
Thanks both, thats why I come here
03 Jul 2021 10:08
I agree, casting marks. To be sure though you could set the pan up on some blocks over a drip pan and fill it with gas. The gas is thinner than oil and will drip through if they are cracks. Might take overnight to confirm.
- idmurp
03 Jul 2021 14:43
Its a really good idea, except I just filled the bike with oil. Its got papertowel underneath it to check for oil leaks like last time, but this time I put the gasket in properly. Will keep an eye on leaks from there anyway.
03 Jul 2021 14:50
Those marks are not cracks. They are simply casting marks as confirmed by others in this thread. Move on to other things to worry about. Have you adjusted the valves lately?
The following user(s) said Thank You: DOHC, SWest
