Engine Casing Repair
- Lebowski
16 Jun 2021 07:34 - 17 Jun 2021 15:27
So, the previous owner of this bike did a number on several of the engine threads around the bike. I was able to fix nearly all of them by rethreading and installing a helicoil. However, one of them was so bad that I have been unable to fix it. As you can see, I tried to use JB weld, tap a hole, and install a helicoil, but it did not go so well.
My next plan was to use some low temperature aluminum welding rods and a blow torch to fill in the spot and then re-tap or I was thinking of trying the technique at the link below with the same low temp welding rods. This is the cover for the clutch/drive sprocket btw. I have no experience with aluminum welding and have heard it can be difficult if you aren't experienced. It doesn't have to look good. I just has to work.
Thoughts?
Anyone have any thoughts on the best way to go about this?
Thoughts?
Last edit: 17 Jun 2021 15:27 by Street Fighter LTD.
- 73z1
Re: Engine Casing Repair
16 Jun 2021 08:01 - 16 Jun 2021 08:02
No eBay APP ID and/or Cert ID defined in Kunena configurationsearch ebay for 6mm nut sert
One of many -
One of many -
Last edit: 16 Jun 2021 08:02 by 73z1.
- Lebowski
- 73z1
16 Jun 2021 08:37
The sprocket cover bolts holes are open, ream to minimum size, the splines hold the nut in place,
- zed1015
16 Jun 2021 08:54 - 16 Jun 2021 08:58I think there's actually a chunk of casting missing.The sprocket cover bolts holes are open, ream to minimum size, the splines hold the nut in place,
The only decent fix may be to get it TIG welded.
It would be better if all that awful bodgers mate JB weld was removed to see the real damage and a better solution can then be suggested..
Last edit: 16 Jun 2021 08:58 by zed1015.
- Lebowski
16 Jun 2021 09:01
Yea, I'll see if I can remove all the JB and get a better picture of the situation. The current picture is probably a little misleading on how bad this is.
- Ian_B
17 Jun 2021 10:08
It indeed looks as if part of the casting is missing. TIG welding is the only way I can think of to do a proper repair, replace the missing metal and then machine / dress up the mating faces, tap the threads etc. It's unlikely that this can be done with the engine assembled, it looks like a complete strip down. If that's the case, I'd check what a replacement engine case would cost - might be cheaper, and then you know it's right.
Ian
Ian
17 Jun 2021 15:41 - 17 Jun 2021 15:41
It’s really hard to find “matching number” Kz bikes after the Z1 run stopped. It’s not as critical to the value of the bike. I agree as mentioned, that buying a set of cases in the correct serial number range would be a more cost affordable way to accomplish your goal.
The 1976 Kz900 engine number range is Z1E086001 - 138846. If you know the month your bike was built you can search for a serial number to get close.
Last edit: 17 Jun 2021 15:41 by Mikaw.
17 Jun 2021 16:18 - 17 Jun 2021 16:32
No eBay APP ID and/or Cert ID defined in Kunena configurationI tried it all. Wound up buying 8mm/6mm inserts thanks to one of our members. Used a m8 helicoil then used the insert. The hole was getting too big for just the insert. Works great.
Start at 8:25
Start at 8:25
Last edit: 17 Jun 2021 16:32 by SWest.
- Lebowski
18 Jun 2021 06:30
Alright, I cleaned the JB weld out. It appears that the previous owner drilled a hole under the hole in question at some point in the past. Strange. I think I'm going to try the low-temp aluminum solder sticks before I do anything else.
- krazee1
18 Jun 2021 06:37
That is really quite fugly, the result of a repair attempt that just kept going further downhill! Good luck with your repair attempt, it can be repaired by a good man with a TIG and some careful reshaping and drilling if all else fails.
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
- zed1015
18 Jun 2021 08:09
You will need a lot of localised heat in the cases to have a chance with the low temp alloy rods and even then the results won't be great.
I've plenty of experience with it and you will need at least an oxy/acetylene torch to have half a chance to beat the heat soaking and ideally the cases stripped bare.
It runs like piss and building it up to form a structure to shape and match the original case isn't what it's any good at.
With a job like that i would personally get it Tigged.
