Spark plug threads on cylinder head
- kzed
21 May 2021 06:09 - 21 May 2021 06:47
Could someone look at this picture and let me know if this will be a huge issue when I reinstall the top end? It looks like the spark plug on cylinder 3 burned a groove in the threads. I’m cleaning everything up. But should I try and tap a bigger thread or leave it as it is and hope for the best. I’d rather not put it back together and pull it off again. I’m in deep right now
Attachment not found
Last edit: 21 May 2021 06:47 by kzed. Reason: Photos
- slmjim+Z1BEBE
Re: Spark plug threads on cylinder head
21 May 2021 06:27
Can't see the pics. Only content that appers is:
"You do not have permissions to access this page.
You do not have permissions to access this page."
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: kzed
- kzed
21 May 2021 06:58
You need an insert installed. Timesert is ideal.
21 May 2021 07:00
- Warren3200gt
21 May 2021 07:18 - 21 May 2021 07:20
Only last pic showing. I dont see how that could happen unless there is a crack from the plug hole to the valve seat. That crack is fairly common and doesn't normally cause huge issues and can be easily welded.
one thing is for sure your valve seats need attention!
Last edit: 21 May 2021 07:20 by Warren3200gt.
21 May 2021 07:50
Appears that groove is eroded deeper than a timesert will fix with out first welding in missing material.
If so , First weld up to fill in. Then finish repair with timesert.
NOTE
Looks like the head needs a complete service
Especially if you dont want to pull it off again for a long time
NOTE
- kzed
21 May 2021 07:50 - 21 May 2021 07:52
Last edit: 21 May 2021 07:52 by Street Fighter LTD.
21 May 2021 07:53
I fixed your picture to be full size .
Next time click the insert all tab
- kzed
- kzed
21 May 2021 08:00 - 21 May 2021 08:02
I’m doing the ton y’all. Completely deep cleaned. I hope I don’t have to open the crack case this go round. That’s a little more time than I can’t afford right now
this is where I’m at today
and hopefully back together by this Sunday!!!!
It’s my own bike. So I don’t mind a 16 hr day working on my personal bike. It’s fun!
Last edit: 21 May 2021 08:02 by kzed.
- kzed
21 May 2021 08:08
Does anyone know what size insert I need on a 79 kz650?
