Cam chain suddenly snaps forward while rolling over by hand (17mm socket)
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
18 May 2021 04:39
#848665
Was checking valve clearances when I noticed what appeared like the intake cam was snapping forward, which was causing sudden slack in between the cams,  ..never seen this before, is something wrong here? Please help if possible. Much thanks
1982 KZ1100D1
  • hardrockminer
  • hardrockminer's Avatar
Re: Cam chain suddenly snaps forward while rolling over by hand (17mm socket)
18 May 2021 04:49
#848666
What engine?
  • zed1015
  • zed1015's Avatar
  • Away
18 May 2021 05:12
#848668
There's always a little bit of give as the cams get pushed over by the valve spring pressure but if there's momentary slack you need to look at the chain tensioner to see if it's backing off under load.
This is the reason APE type manual tensioners are the popular choice.
  • Gdailey2112
  • 82 KZ1100D1
18 May 2021 13:15
#848698
Ahhh I see, I was worried. Nah, its not really causing excessive slack, just a notable amount slack. I'm using a stock tensioner, and am now looking into getting an APE manual type of tensioner. Thank you for the info!
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
18 May 2021 16:44
#848710
 Manual tensioners require careful adjustment to make sure they are set properly.  A lot of guys overtighten which is worse case.  The stock tensioners work well assuming they are not binding up or whatever.  I like to take them off, replace the seals, and check smoothness of operation.  Assuming they are working as designed I slap them back on and don't worry further.
The following user(s) said Thank You: loudhvx, 650ed, Rick H.
