Head Gasket Repair
- 82KZ305Belt
Head Gasket Repair
01 Apr 2021 05:59
I finally found someone to repair my 305's head gasket but he wants me to order all needed parts. What do I need, other than the head gasket??
81 KZ650 CSR
77 KZ650B (not in my paws yet)
82 KZ305 CSR
82 KZ305 CSR
- zed1015
Re: Head Gasket Repair
01 Apr 2021 06:05
Buy yourself a top end gasket set.
It should include all you need including exhaust gaskets and the valve stem seals if needed which are worth replacing whilst the head is off.
- 82KZ305Belt
01 Apr 2021 06:28
No eBay APP ID and/or Cert ID defined in Kunena configurationAt first I thought you meant "high quality" by top end but I realize you just mean top end of the engine. But it begs the question, are all gasket sets created equal? I see Vesrah, Athena and this no-name "aftermarket" brand
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- zed1015
01 Apr 2021 07:29
Go for the higher quality Vesrah / Athena ones and steer clear of anything no name.
01 Apr 2021 09:34
I have used Vesrah, which I think are very good, but for a head gasket I would go with OEM. The problem is that they are hellishly expensive.
- gordone
01 Apr 2021 09:59 - 01 Apr 2021 10:00
In the longe run you save money and time using OEM parts in general?
Project:
Project:
Last edit: 01 Apr 2021 10:00 by gordone.
01 Apr 2021 10:36
Athena is garbage.
- 82KZ305Belt
01 Apr 2021 10:38
OEM is apparently not available, at least the major ones needed.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- 82KZ305Belt
01 Apr 2021 10:40I hope that's a vote for the Vesrah, because that's about all that's left...Athena is garbage.
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
- Kaylinator
01 Apr 2021 13:10
Vesrah is about the best you can get short of OEM.
1978 KZ1000-A2
1978 KZ400-B1
2022 Z900RS SE
1978 KZ400-B1
2022 Z900RS SE
- 82KZ305Belt
01 Apr 2021 14:59 - 01 Apr 2021 15:14
Vesrah gasket kit has been ordered. Now what about valve stem seals? Any to stay away from or look for, if I can't find OEM?
Also this will be done by a guy who is not a classic bike expert. Anything about these old bikes I should warn him about, or that I should be prepared for him to screw up?
81 KZ650 CSR
82 KZ305 CSR
82 KZ305 CSR
Last edit: 01 Apr 2021 15:14 by 82KZ305Belt.
01 Apr 2021 15:45
When pulling the head the cylinder should be removed so the base gasket can be replaced too. And some people like to replace the rings at the same time. Guess that last part depends on the overall condition and wear on the bike...and the cost of the rings.
The following user(s) said Thank You: 82KZ305Belt
