Kz200 starting problems
  • Provie97
  • Provie97's Avatar Topic Author
23 Jan 2021 06:45
#842233
I’ve got a 1978 kz200 I came across a little while back that has 500 miles on it but had been sitting up for a couple decades. When trying to start it up, it goes to turning over then makes a grinding/ clacking noise.
  • Nessism
  • Nessism's Avatar
The following user(s) said Thank You: Provie97
  • Provie97
Re: Kz200 starting problems
23 Jan 2021 14:42
#842264
I didn’t know for sure and needed some opinions. The bike only has 500 miles on it and I wasn’t wanting to go into the motor any more than I had to. Would this effect the actual clutch? I can shift in a d out of all gears, but when I’m gear and pull the clutch to move it around I get nothing. I can hear and feel the that it’s pushing the rod in but that’s all I get
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
25 Jan 2021 04:32
#842348
Hey, what Nessism is saying that in order for your starter motor to engage your crank to turn you engine over there is a starter clutch to engage and release when you start. This system can fail easy enough in older unused bikes. The starter clutch has nothing to do with your actual clutch, below is a pic of the system.
  • Provie97
25 Jan 2021 08:29
#842356
Ok thank you. For the help. I’m still trying to figure out how to maneuver around on here. I’ve lost 2 pretty long messages that had a lot of background of what I’d done with the bike so far and was getting frustrated. That’s why the short entries sorry. I’ve tried to post pictures of the before and after but have no clue where rose went lol
Attachment not found
  • Provie97
25 Jan 2021 08:37
#842357
How do you post pics, I be going through the attachment option and it’s not cooperating
  • kzstreetfighter71
25 Jan 2021 08:54 - 25 Jan 2021 08:56
#842359
post from a computer, laptop or tablet if you can and under where you type there is an Attachments icon, press it then add files then the insert all tab and it will drop the url code into your message then submit, that will get you sorted. and never mind the pic of the gpz1100 i was just using it an example and it posted by mistake.
Last edit: 25 Jan 2021 08:56 by kzstreetfighter71.
  • Provie97
25 Jan 2021 10:04 - 25 Jan 2021 10:05
#842366
Thank you sir. Hopefully here’s a couple pics of the bike
Last edit: 25 Jan 2021 10:05 by Provie97.
  • Provie97
25 Jan 2021 10:08
#842368
  • Provie97
25 Jan 2021 10:11
#842369
  • Provie97
25 Jan 2021 10:14
#842370
Lmao!! I think I got it. Didn’t mean to post so many and no telling how I got a couple upside down. You have to at least 2 % smarter than what your working with and I think I’m lacking
  • kzstreetfighter71
25 Jan 2021 10:33 - 25 Jan 2021 10:34
#842372
Nice tidy bike there the first 2 were a mulligan . is the engine turning over freely on a slow kick?
Last edit: 25 Jan 2021 10:34 by kzstreetfighter71.
