1976 KZ900 Head Gasket
- apachejxck
01 Dec 2020 20:04
I need some guidance fellas. My father recently passed away and he was in the process of rebuilding his custom 1976 KZ900. The engine was bored out to a 1425 and the increase in compression blew the head gasket. I have the bike with me and I want to finish the rebuild and get the bike on the road but I don’t have much experience working on bikes. At the moment the head is removed and I have a replacement gasket. I know it needs sealed on and then the head reassembled and cams retimed but have never done a task like this myself. I was wondering if anyone could give me some tips or guidance it would be extremely appreciated.
- zed1015
Re: 1976 KZ900 Head Gasket
02 Dec 2020 09:37
At 1425cc i presume it is a copper head gasket.
It so then spray coat it both sides with Loctite 3020.
Build it up in several light coats and let it dry to a uniform colour then fit.
The motor should be fitted with HD cylinder studs and torqued down to 42 ft/lb
Repeat when the engine has cooled fully after the first heat cycle .
- apachejxck
02 Dec 2020 09:43
Appreciate the help. Do I need to replace the piston rings and are there metal o-rings that sit in the cylinders on this model?
- zed1015
02 Dec 2020 10:58
The gasket face of the block should have grooves around the top of the liners with stainless or copper wire etc installed ( commonly known as piano wired or 'O' ringed ) that sits slightly proud of the surface that will bite into the copper head gasket to provide a better seal.
The actual piston rings should not need replacing if it's a fresh build or low miles and only if you have low compression, oil burning, smoking exhaust due to high mileage wear or glazed bores. etc..
02 Dec 2020 11:32
When you put the cams back in place you will have to time them correctly. Best to find a book with the correct steps to follow when you do so.
- Rick H.
02 Dec 2020 13:01
Hardrock beat me to the punch. If you don't have a service manual by all means get one and read over the appropriate areas a couple of times. After doing so you will no doubt have further questions which is okay and will be gladly answered.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
