Stock KZ750 cylinder liner thickness?
  • ghostdive
  • ghostdive's Avatar Topic Author
27 Sep 2020 18:53
#835750
I’m thinking I might try something new with my potential upcoming overbore, but I’m not sure how much I’ve got to work with. I know the Wiseco 810 is 69mm, and I’ve heard of an upper 800s engine, but I don’t know if that was stock sleeves. I may as well say that I’m hoping to use some Z800 (71mm) pistons...but I’m prepared to find something a bit more reasonable if I must.
2001 ZX-6R
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: Stock KZ750 cylinder liner thickness?
28 Sep 2020 03:35
#835763
You will have to resleeve. Also check wrist pin diameter and pin height.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • DoctoRot
  • DoctoRot's Avatar
28 Sep 2020 11:11
#835781
I don't know what the sleeve OD is but it may be possible to do Nikasil coating and ditch liners all together.
  • DFIGPZ
  • DFIGPZ's Avatar
28 Sep 2020 12:51
#835791
if this is KZ750 / 4cyl you can bore stock sleeves to 810cc but you better have them centered perfect, I done many 750 turbos to 810 sleeves are so thin you can squeeze enough to distort them, I ran this set up 20,000 miles on my 750 turbo W/O issue ! I also had 750 / 4 drag bike with 810 kit an ran for 7 seasons W/O issue
1984 750 Turbo
  • ghostdive
28 Sep 2020 18:55
#835817
Thanks for the input, everyone. I'll put this idea on the far back burner.
2001 ZX-6R
  • Injected
  • Injected's Avatar
29 Sep 2020 09:12
#835852
The stock KZ/GPZ750 liner is 71.49mm OD
Boring to 69mm for 810cc leaves a very thin liner wall that can distort easily.
1978 KZ650B2 modified project
