1/4 turn output shaft at sprocket
- 1981kz750ltd
19 Aug 2020 13:54
While preparing to replace the sprocket gaurd I noticed about a 1/4 turn back n forth on the output shaft at the sprocket. . I could feel this while riding but attributed it to the chain.
Fix? The repair manual is vague. Thanks
Tried to load a video but won't accept mp4
Re: 1/4 turn output shaft at sprocket
19 Aug 2020 14:03
There will be a little play at the countershaft. What you're feeling while riding might be the chsh rubbers are worn out.
The following user(s) said Thank You: 1981kz750ltd
19 Aug 2020 15:22
If the transmission is in gear and the sprocket will move 1/4 turn, there is a problem. If the 750-4 clutch has rubber dampers and they have disintegrated, the output shaft might have some serious slop.
- 1981kz750ltd
20 Aug 2020 05:57
My apologies. I forgot to mention this is on a 900cc engine. 1/4 turn back n forth at sprocket output shaft while in gear.
20 Aug 2020 07:40
1/4" or 1/4 turn? That's a lot. A video would help. I suspect it would be 1/4". Is there a lot of noise and can you pull the shaft in and out. With the sprocket tightened there should be none.
- 1981kz750ltd
20 Aug 2020 11:37
I did attempt to load vid in first post. Unfortunately my camera records in mp4 which is not supported on the forum.
- M_a_t_t
20 Aug 2020 11:50
You can upload it to youtube and then link it here. All it takes is a google account.
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
21 Aug 2020 12:08SWest wrote: 1/4" or 1/4 turn? That's a lot. A video would help. I suspect it would be 1/4". Is there a lot of noise and can you pull the shaft in and out. With the sprocket tightened there should be none.
In the pictures he posted, it looks like 1/4 turn. That would really worry me.
21 Aug 2020 12:18 - 21 Aug 2020 12:211981kz750ltd wrote: My apologies. I forgot to mention this is on a 900cc engine. 1/4 turn back n forth at sprocket output shaft while in gear.
The 900 clutch has damper springs. Even if all of them were completely missing, there would not be that much slop. I bet there is something broken in the transmission. It might be time to drop the oil pan and look for chunks.
Last edit: 21 Aug 2020 12:21 by TexasKZ.
