1981/82 KZ440 Valve adjusting caps
  • Nebr_Rex
  • Nebr_Rex's Avatar
Re: 1981/82 KZ440 Valve adjusting caps
08 Aug 2020 18:50
#832455
Be really careful tapping on those nuts. They are a thin shell of a casting.
I have rounded off a few with an adjustable wrench. In a pinch a hammer
and chisel to break it loose as not to damage the hex head. Then when reinstalling
apply grease to the mating surfaces and just snug the nut. To much torque
with dry surfaces is the cause of the problem.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
08 Aug 2020 18:57
#832458
I would soak them with Kroil for a few days and then try to remove them. Ed
  • Grcko
  • Grcko's Avatar
09 Aug 2020 08:08 - 09 Aug 2020 08:21
#832471
Just a heads up on tightening them up. I just had one split on my bike. I found that the reason was after years of tightening it, the threaded part had split a bit from the outer ring. I just snug mine up a bit.
I just checked mine and it is a 27mm.
As Always,
1983 KZ440
Last edit: 09 Aug 2020 08:21 by Grcko.
The following user(s) said Thank You: bluejacobs
  • gavroyer
  • gavroyer's Avatar
10 Aug 2020 14:45 - 10 Aug 2020 14:46
#832580
Unless it's a very thin socket or the engine is removed from the bike, you will need to use a wrench to remove them. A socket will not fit on the exhaust caps between the rocker box and the frame.
1980 KZ440-A1 LTD
Last edit: 10 Aug 2020 14:46 by gavroyer.
  • bluejacobs
  • bluejacobs's Avatar Topic Author
17 Aug 2020 16:29
#833124
Grcko wrote: Just a heads up on tightening them up. I just had one split on my bike. I found that the reason was after years of tightening it, the threaded part had split a bit from the outer ring. I just snug mine up a bit.
There we go that’s the ticket! 27mm works great. So I took one off (currently fighting to get a sheared carb holder stud out....) and looks like someone did threadseal them who knows when.... lots of flaky black crap on the threads... I’m sure some fell inside when I pulled the cap... now what.
1981 Kawasaki KZ750 LTD - crashed 4/24, rebuilt and rode the rest of the year; undergoing DD/TLC
1981 KZ440 A - was running until the end of 2022, sitting in a barn for now
1981 KZ440A - donor bike
  • Grcko
  • Grcko's Avatar
18 Aug 2020 07:14
#833147
I don't know if it needs to be cleaned out but personally I would pull the cylinder cover off and clean the crap out.
As Always,
1983 KZ440
  • bluejacobs
08 Nov 2020 07:15
#838239
Unrelated to the original topic of this post, but does anyone know, definitively, what the hell the hose sizes are for the vacuum and fuel lines for a 1981 KZ440 A ??
Every post I find and every search I do turns up nebulous results and incomplete answers.
Cheers
  • Nebr_Rex
  • Nebr_Rex's Avatar
09 Nov 2020 05:08
#838274
Try using this.
2002 ZRX1200R
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
The following user(s) said Thank You: TexasKZ
  • bluejacobs
21 Nov 2020 04:24
#838698
Thanks but I think I’m having trouble getting it to print to the correct scale.
  • TexasKZ
  • TexasKZ's Avatar
21 Nov 2020 06:17 - 21 Nov 2020 06:26
#838703
No eBay APP ID and/or Cert ID defined in Kunena configurationDo you not have a ruler, tape measure, carpenter's square, or other measuring device in your house? Does a neighbor have one you can borrow? You can buy them at any hardware or lumber store.
I am sure this one is accurate enough for this project.
If you are dead set against buying a tool, then buy two or three sizes of hose. Use the one that fits, and take the rest back.
Last edit: 21 Nov 2020 06:26 by TexasKZ.
  • bluejacobs
10 Dec 2020 17:32
#839766
Okay so here's another great question that I'm sure will go unanswered - had a starter clutch go one one bike and fortunately had a low mileage parts bike to pull one from. I was able to borrow a tool to get the respective alternator pulleys off, but now I wonder does anyone have any helpful tips on properly torquing the pulley bolt (LH, 51 ftlbs) without the "special" pulley holder tool? Have not for the life of me found anything good, and none of the homebrew solutions I've tried have worked so far.
Cheers to all.
  • Mikaw
  • Mikaw's Avatar
10 Dec 2020 18:23
#839769
Im pretty sure you can put the bike in gear and have someone stand on the rear brake. That should keep the crank from turning.
