84 zn700a sprag
  • Joshn569
  • Joshn569's Avatar Topic Author
84 zn700a sprag
26 May 2020 16:54
#826596
Do any other models use the same starter clutch, or maybe a better on that will bolt right in?
  • GPZenthusiastic
  • GPZenthusiastic's Avatar
Re: 84 zn700a sprag
27 May 2020 16:00
#826683
Hi There ,
I'm not 100% certain about this but since nobody replayed to you yet I can tell you :
As far as I know all kz 750 and 700 share the same engine also , I believe Kz 650 does too.
Not the cylinders (obviously) but I'm sure the starter is the same.
All the best
The following user(s) said Thank You: Joshn569
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 84 zn700a sprag
27 May 2020 16:22
#826685
Daftrusty´s 6-speed Transmission with ZR7S parts
kzrider.com/forum/11-projects/602462-kz7...-mod?start=36#737632
and weeZee´s kz650 starter clutch solution - with ZR7S parts
kzrider.com/forum/2-engine/607684-kz650-...-part?start=0#777461
  • H1Vindicator
  • H1Vindicator's Avatar
Re: 84 zn700a sprag
28 May 2020 08:21
#826741
partzilla has an x-ref.
  • Joshn569
Re: 84 zn700a sprag
28 May 2020 10:13
#826751
Scirocco wrote: Daftrusty´s 6-speed Transmission with ZR7S parts
Thanks, I did search and see this thread but I was unsure if kz65o was the same part
  • Joshn569
Re: 84 zn700a sprag
28 May 2020 10:18
#826752
I had looked up the parts on kawaski.com/parts and I picked 1984 ltd shaft. Wrote down the part #'s and ordered them. The clutch cover gasket showed up first and it was wrong, then the sprag came next and was also wrong. I looked everything up again but by vin # this time and sure enough all the parts had different part #'s. Not sure how or why that happened, but know that I think I have the correct part numbers so I will try to cross reference them.
Thanks for the replies. It's a little bit of work to change out the starter clutch so I want to make sure I do it right
  • martin_csr
  • martin_csr's Avatar
Re: 84 zn700a sprag
28 May 2020 10:42 - 28 May 2020 10:49
#826753
The 84 Ltd Shaft at Kawasaki.com is a KZ550. needless to say, the Kaw diagrams aren't very good. in cases like yours you have to type the model in the address bar in place of the model shown in the address. Partzilla is easier to use & has a cross-reference.
Last edit: 28 May 2020 10:49 by martin_csr.
Re: 84 zn700a sprag
28 May 2020 11:59 - 28 May 2020 12:01
#826756
Joshn569 wrote: I had looked up the parts on kawaski.com/parts and I picked 1984 ltd shaft. Wrote down the part #'s and ordered them. The clutch cover gasket showed up first and it was wrong, then the sprag came next and was also wrong. I looked everything up again but by vin # this time and sure enough all the parts had different part #'s. Not sure how or why that happened, but know that I think I have the correct part numbers so I will try to cross reference them.
Take a look at the link below to see if that is the one for your bike. It isn't a ZN model, but it does list the shaft drive. Ed
www.kawasaki.com/Parts/PartsDiagrams/1984/KZ700-A1
Last edit: 28 May 2020 12:01 by 650ed.
  • martin_csr
Re: 84 zn700a sprag
29 May 2020 06:35 - 29 May 2020 08:09
#826823
By 650ed: Take a look at the link below to see if that is the one for your bike. It isn't a ZN model, but it does list the shaft drive. Ed
The KZ700 is a chain drive, so it won't be the same as the ZN700. The model lookup page lists an Ltd Shaft but doesn't specify which one it is. In the link you provided, he could simply change KZ to ZN. That's what I did below.
httpz://www.kawasaki.com/Parts/PartsDiagrams/1984/KZ700-A1 >> www.kawasaki.com/Parts/PartsDiagrams/1984/ZN700-A1
Last edit: 29 May 2020 08:09 by martin_csr.
Re: 84 zn700a sprag
29 May 2020 06:46 - 29 May 2020 06:47
#826824
martin_csr wrote: By 650ed: Take a look at the link below to see if that is the one for your bike. It isn't a ZN model, but it does list the shaft drive. Ed
Oooops! You are correct. What confused me was the words "Shaft, Drive" and "Shaft Output" for the first two part numbers in the "Transmission" drawing. However, looking more closely shows those do not refer to a shaft drive bike. Ed
Last edit: 29 May 2020 06:47 by 650ed.
  • loudhvx
  • loudhvx's Avatar
Re: 84 zn700a sprag
29 May 2020 06:47 - 29 May 2020 06:50
#826825
I've found it easier to do what Martin suggests... simply type the actual year and model into the address bar. You have to make no typos and you need to know all of the actual year and model designation letters for the specific bike.
It seems to only work when you are on the main page for a particular bike. That is the page with all the fiche thumbnails. Once you are in a particular part page (like the exhaust system fiche, or the ignition system fiche) you have to back out to change the model.
Somewhere, we should have a sticky with all of the Kz models with year and letter-number designation, with marketing name, like "Ltd" etc., and maybe a short description of what makes that model unique so it can be identified easily. Once you have that list, it's easy to find models on the kawasaki site. As it is now, you have to know that when they list Gpz, they might only show the listing for the 550 Gpz, but you might need a 750 or 1100 gpz. So you'd have to know to enter the model and year into the address bar. If you don't know the designators, you would be out of luck.
The 550's are pretty easy, and I have them listed somewhere. I also have most 400's and many 650/750's. I'll see if I can start putting together something. I guess it would only be U.S. models. It's difficult to get non-U.S. information.
Last edit: 29 May 2020 06:50 by loudhvx.
  • Joshn569
Re: 84 zn700a sprag
29 May 2020 18:19
#826895
Ok I need the 13193 1012 and it superceded to 13193 1062. Thanks for the help! This is why I'm not a parts guy
