'81 KZ1000 J engine clattering noise- cam chain? Should I go manual adjuster?
- EksCelle
18 May 2020 15:37
Hey all, my 1981 KZ1000 LTD has started making a clattering noise lately. The bike still runs great- I think it's the cam chain. It's got the factory automatic tensioner. I've been looking at the APE manual cam chain tensioners, is that the way to go for a stock bike?
I took a video of the noise and while it doesn't do a great job capturing it, it still got it. Any help would be appreciated!
1981 KZ1000 LTD
Re: '81 KZ1000 J engine clattering noise- cam chain? Should I go manual adjuster?
18 May 2020 15:40
How many miles on the bike?
- EksCelle
18 May 2020 15:50
Hey Steve, just over 23k on the odo.
1981 KZ1000 LTD
18 May 2020 15:58
The adjuster may be stuck. Do you have a manual
The following user(s) said Thank You: EksCelle
- EksCelle
18 May 2020 16:37
Unfortunately I do not
1981 KZ1000 LTD
18 May 2020 17:14 - 18 May 2020 17:14That's ok. Here's a link to the manual. EdEksCelle wrote: Unfortunately I do not
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
Last edit: 18 May 2020 17:14 by 650ed.
18 May 2020 17:22
Have you synchronized the carburetors lately? If they are out of adjustment, the cam chain will rattle.
- EksCelle
18 May 2020 17:44TexasKZ wrote: Have you synchronized the carburetors lately? If they are out of adjustment, the cam chain will rattle.
I have not, the manual Ed linked makes it seem pretty straightforward. Is it possible to do without the gauge set in the manual? I only own 1 vacuum gauge.
1981 KZ1000 LTD
18 May 2020 17:54
You cannot do it with one guage, since each adjustment will affect the readings on the other carbs. If you buy a guage set, buy an expensive one. The cheap ones will turn you into an ax murderer. Some folks here are fans of the Morgan Carbtune. Some old timers swear that Mercury sticks are the only way to go.
- EksCelle
18 May 2020 20:24
Money's an issue right now what with the pandemic and all. I'll see if I can find a shop nearby that can do it for a cost that won't kill me.
In the meantime I may just take off the existing tensioner and see if I can't clean it out. The manual is very sparse on details about it. I would really hate to have to buy another OEM one or an aftermarket manual one.
1981 KZ1000 LTD
18 May 2020 20:31
If you take it off don't turn the engine until you reinstall it. I'd pull the valve cover, check the valve clearances and check if the guides aren't broken.
