1982 KZ1000, Cracked Clutch Spring Cover
  • mjudge
  • mjudge's Avatar Topic Author
13 May 2020 13:34
#825644
Hi all, I took my clutch apart as it was not going into gear and the consensus was the plates were stuck. Freed up the plates, and when putting back together noticed these cracks around the clutch spring cover hole. Anyone else ever have this problem? Looks like I'll need another if anyone has one...thanks!
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: 1982 KZ1000, Cracked Clutch Spring Cover
13 May 2020 14:01
#825646
Ouch !!!
I would scrap it for sure.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 May 2020 15:39
#825654
This are not cracks , only embossed casting marks!!!
  • mjudge
13 May 2020 16:00
#825656
Thanks for your reply; I see you also replied to my Wanted ad.
Man, these sure look like cracks to me, and on eBay I see others without them. Hopefully you can see why I'm concerned. Would you feel comfortable putting this back on? Not that I'm doubting you!
Maybe some else can chime in to make me feel better about reusing it. Thanks!
  • TexasKZ
  • TexasKZ's Avatar
13 May 2020 16:50
#825673
Can they be seen on the other side?
  • Moderator
  • Moderator
13 May 2020 16:55 - 13 May 2020 16:56
#825674
Scirocco wrote: This are not cracks , only embossed casting marks!!![/quote
]Are you sure ?/ I guess I would like to compare it to another one
:S
Last edit: 13 May 2020 16:56 by Street Fighter LTD.
  • mjudge
13 May 2020 17:40
#825679
They don't seem to go through into the holes the springs/bolts sit in, and nothing on the back. If they are embossed (raised?) marks they should smooth out with a file, which I'm going to try now...
  • krazee1
  • krazee1's Avatar
13 May 2020 17:52
#825682
Penetrating dye and developer are a good check for cracks. Some casting flaws can be deceiving, but in the picture those appear to be cracks to me.,
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 May 2020 17:55
#825683
Pic of the underside? There may be other things to look at.
  • mjudge
13 May 2020 18:08
#825685
Well, I think I owe Scirocco an apology...when I took a file and sandpaper to one of the "cracks", it smoothed out and I can't catch a fingernail on it. They look like tiny metal raised "veins" that I swore were cracks, but do not appear to be.
  • Moderator
  • Moderator
13 May 2020 18:14
#825686
mjudge wrote: Well, I think I owe Scirocco an apology...when I took a file and sandpaper to one of the "cracks", it smoothed out and I can't catch a fingernail on it. They look like tiny metal raised "veins" that I swore were cracks, but do not appear to be.
Glad it worked out .
It looked nasty
  • loudhvx
  • loudhvx's Avatar
15 May 2020 08:13
#825800
Similar lines appear on the underside of cush-drive hubs on the rear wheel. They had me worried until I noticed all of my bikes had them. When things are clean, they down't show up as much.
