Kz1000 barrels onto KZ900 cases
  • BCKZ
  • BCKZ's Avatar Topic Author
13 Apr 2020 11:03
#823248
I'm going to fit KZ1000 barrels onto KZ900 cases, do I need the rubber O rings on the base of barrels?
  • kevski
  • kevski's Avatar
Re: Kz1000 barrels onto KZ900 cases
13 Apr 2020 11:05
#823249
If the provision is there on the barrels then yes, i believe this was a remedial thing.
The following user(s) said Thank You: BCKZ
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Apr 2020 12:35
#823254
Short answer NO. You may have to relieve around the back of the case a little for them to fit. I did it without doing it but this last time I did. The locating pins weren't fitting right and that was part of a leak. Some fit some don't.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Apr 2020 13:44 - 13 Apr 2020 13:44
#823256
You have to extend the line bore Diameter of the sleeve openings (min. ID = 76 mm) into the crankcase
for the KZ1000 cylinder block (OD sleeves = 75 mm).
Last edit: 13 Apr 2020 13:44 by Scirocco.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Apr 2020 15:25 - 13 Apr 2020 15:42
#823271
Made a clip on the subject.
Last edit: 13 Apr 2020 15:42 by SWest. Reason: add clip
