1977 kz 750 twin, points engine.
- droom
12 Mar 2020 14:35
new member here.....
i have a kz 750 twin engine i bought for $ 100.00 , it has the carbs & the starter......
i want to use this engine for a street rod, how can i wire it up to run.....it is a points engine , so i don`t think it has electronic ignition......any idea where to start ?
thanks i really need this info.
Re: 1977 kz 750 twin, points engine.
12 Mar 2020 16:54 - 13 Mar 2020 04:42
What year is the 750? Asking as the charging systems tend to vary. There's a topic on KZR by loudhvx with simplified wiring diagrams for various KZs & there are several for the 750B & 750G models which have points ignition. In his diagrams you would use almost everything on the LH side to run the engine.
KZR topic >> bare bones for mattylight by loudhvx >> See pgs 11-on (note: some of the diagrams may be gone. pgs. 1-10).
750G on pages 15 & 17. 750B on pages 18 thru 21. possibly others. .... wire gauge >> see pg 12 near the bottom
Last edit: 13 Mar 2020 04:42 by martin_csr.
- loudhvx
13 Mar 2020 04:22 - 13 Mar 2020 04:25
The 76 and 77 kz750 twins use very specialized regulators. Luckily, oregonmotorcycleparts.com knows and has exactly what you need... When it comes time to get the charging system working.
The points are standard like any other points equipped kz.
If you want to run a modern ignitor using the points as a trigger, you can eliminate the condenser.
s3.amazonaws.com/gpzweb/Ignition/GPZhei7pinModForPoints.html
As Martin mentioned there are a few 750 twin diagrams in the mattylight thread.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Mar 2020 04:25 by loudhvx.
