Cylinder 2 and 3 not working
- JoseReyes23
- Thank you received: 2063
No picture is attached.
What kind of bike is this for ?
No bike description is given
I will watch for it
- Thank you received: 2818
- JoseReyes23
Is there fuel in all the float bowls ?
Its probably electrical , Ive learned to check everything ..
Do you have a factory Manual ?
- ThatGPzGuy
- Thank you received: 385
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- JoseReyes23
I dont have the manual if you guys can help to identify what engine it is the only thing was the stamp on it ZXT00AE041517
I would check valve clearance but dont have the manual for it and also if i have good compression dosen't it means that valve clearance is good?
I was goin to start to think is the igniter that is not sending the spark at the correct time but im just taking wild guess just starting to learn about motorcycle engines
- Thank you received: 2234
www.kzrider.com/modules/ServiceManuals/G...R_Service_Manual.pdf
- JoseReyes23
I also noticed it only hace one pick up coil and most manual shows 2 of them. I appreciate any more ideas
- Mrk
Confirm you have vacuum on those two cylinders.
You may not be getting an air-fuel mixture into the cylinders.
75 Z1 900 Kerker
77 KZ 650 B1 DynaKit+Kerker
85 ZL 900 A1 Eliminator
- Thank you received: 1918
He quietly mentions... " I was told it's a GPZ1100..."
JoseReyes23 wrote: I did check valve clearance and they are within spec, im cheking wire harness tomorrow any more ideas, could the igniter cause to send the spark at the wrong time?
I've not worked on that particular model before but I thought there needs to be two pickup coils. I'd focus on this first...
