Cylinder 2 and 3 not working
  • JoseReyes23
  • JoseReyes23's Avatar Topic Author
23 Dec 2019 05:05
#815766
I'm having problems getting the bike running it will star but only 1 and 4 are running I have tested the coils and they work all of them have spark y have done compression test on all cylinders and is good I have cleaned and swapped carburetor and still no luck what other test o can do? I have attached an picture of my engine if someone can tell me what it is i will help thanks
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Cylinder 2 and 3 not working
23 Dec 2019 05:35
#815767
Jose
No picture is attached.
What kind of bike is this for ?
No bike description is given
I will watch for it
  • Nessism
  • Nessism's Avatar
23 Dec 2019 05:38 - 23 Dec 2019 12:12
#815768
One coil fires 2&3 and the other 1&4. You might want to switch them up to see if you can get 2&3 firing. That way you will know that either the coil is bad or the carbs are plugged up.
Last edit: 23 Dec 2019 12:12 by Nessism.
  • JoseReyes23
23 Dec 2019 14:05
#815788
I was told it was a gpz 1100 the engine number is ZXT00AE041517, i have switched the coils around thats how a know that they work and also have taken out all the sparkplugs at the same time and all of the have strong spark and since it hase compression I assume it was the carburetor but I cleaned the set that is on and try drifrent ones and the engine will start but only 1&4 the header will get hot, that where I'm at and stuck
  • Moderator
  • Moderator
23 Dec 2019 15:38
#815796
Does the bike have 2 fuel lines ? Long shot is check for good fuel flow.
Is there fuel in all the float bowls ?
Its probably electrical , Ive learned to check everything ..
Do you have a factory Manual ?
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
23 Dec 2019 16:58
#815797
Have you checked valve clearances?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • JoseReyes23
23 Dec 2019 17:16
#815798
Yes I'd have double check the fuel in the carburetors and all the float bowls had fuel in them i have also dump fuel inside wile is running to see if something happens and nothing.
I dont have the manual if you guys can help to identify what engine it is the only thing was the stamp on it ZXT00AE041517
I would check valve clearance but dont have the manual for it and also if i have good compression dosen't it means that valve clearance is good?
I was goin to start to think is the igniter that is not sending the spark at the correct time but im just taking wild guess just starting to learn about motorcycle engines
  • TexasKZ
  • TexasKZ's Avatar
23 Dec 2019 19:15
#815799
I think this manual should cover your bike, but check the frame numbers on the last page to be sure.
www.kzrider.com/modules/ServiceManuals/G...R_Service_Manual.pdf
  • JoseReyes23
27 Dec 2019 16:47
#815965
I did check valve clearance and they are within spec, im cheking wire harness tomorrow any more ideas, could the igniter cause to send the spark at the wrong time?
I also noticed it only hace one pick up coil and most manual shows 2 of them. I appreciate any more ideas
  • Mrk
  • Mrk's Avatar
27 Dec 2019 17:12 - 27 Dec 2019 17:47
#815969
Take a look at the carburetor boots for 2,3 (leaks).
Confirm you have vacuum on those two cylinders.
You may not be getting an air-fuel mixture into the cylinders.
75 Z1 900 Kerker
77 KZ 650 B1 DynaKit+Kerker
85 ZL 900 A1 Eliminator
Last edit: 27 Dec 2019 17:47 by Mrk.
  • Mikaw
  • Mikaw's Avatar
27 Dec 2019 17:32 - 27 Dec 2019 17:33
#815971
Of no help but I just had to throw in my $,02....
He quietly mentions... " I was told it's a GPZ1100..."
Last edit: 27 Dec 2019 17:33 by Mikaw.
  • Nessism
  • Nessism's Avatar
27 Dec 2019 18:31
#815974
JoseReyes23 wrote: I did check valve clearance and they are within spec, im cheking wire harness tomorrow any more ideas, could the igniter cause to send the spark at the wrong time?
I've not worked on that particular model before but I thought there needs to be two pickup coils. I'd focus on this first...
