Rebuild engine storage
  • Ojisan rider
  • Ojisan rider's Avatar Topic Author
15 Oct 2019 17:18
#812528
Aloha guys.
Question about how to store your engine while it's been rebuild.
Currently, my engine sits in a living room (my wife gave up on that). It's clean without any oil, except assembly lube at the crank and con-rod bearing. And naturally, all the moving parts.
Anyway, I'm about to put the pistons and jug on the crankcase. Once that is done, head cam and all other stuff will go back on, but I know I won't be able to finish all that in one day. So! Just how do you store a rebuild engine for few month? Yes, I will oil the jug before I put the piston back in but will that be enough? I should mentioned that lately, we been bit on humid side.
Oh, and BTW, can someone shed me some light on how to install the engine studs that hold the cylinder and the head? I do have stud removal tool which made some nasty marks on the studs, but is there another way besides that tool or double nuts? I tried the double nuts method but there was a reason why I bought that revmoal tool..................
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
  • zed1015
  • zed1015's Avatar
Re: Rebuild engine storage
16 Oct 2019 11:05 - 17 Oct 2019 04:25
#812556
As long as the engine components are lubed and the storage area is dry you should have no problem storing for a few months..
If the air is excessively damp then you could bag up the motor to keep the air out.
For the cyl studs , use a cylinder head nut with a 6mm or 8mm ball bearing inside and torque the stud down.
The nut will release easily once done .
If you want to part with some money though you could buy the correct tool.
www.toolstoday.co.uk/sealey-motorcycle-s...iEAQYASABEgK6BfD_BwE
If you look carefully at the top of the studs you will see a small dimple left by the factory stud installation tool which works exactly the same.
Last edit: 17 Oct 2019 04:25 by zed1015.
  • Ojisan rider
25 Oct 2019 00:06
#812978
Thanks for the info. I'm specially concern after I install the piston and put the jug back on.
Anyway, I'll look for the stud installation tool. I don't mind paying for tools like that as I know I will be using it down the road somewhere. BTW, I tried your link but they don't list USA in their country list................
Anyway, thanks!
  • zed1015
  • zed1015's Avatar
25 Oct 2019 03:04
#812979
No eBay APP ID and/or Cert ID defined in Kunena configurationPlenty on EBAY that ship to USA.
  • Ojisan rider
26 Oct 2019 00:04
#813044
zed1015 wrote: Plenty on EBAY that ship to USA.
Damn! One day I forgot to check evilbay, someone is already on it!:lol:
Anyway, thanks for the info. I never thought evilbay will carry them. Guess I should try them always.
  • TexasKZ
  • TexasKZ's Avatar
26 Oct 2019 06:18
#813050
Scroll down the page a bit. These are always available.
racetoolz.com
  • Ojisan rider
27 Oct 2019 00:58
#813108
TexasKZ wrote: Scroll down the page a bit. These are always available.
racetoolz.com
Thank you very much for the link. Other stuff look good also!
I must admit, I'm getting old. getting little (little?) rusty finding or looking for some stuff on the net. Too much "hey Google", I think.
