Crankcase
- richard-GPZ
Crankcase
25 Sep 2019 13:29
I recently bought a crankcase to use on an engine project for my 1983 GPZ-1100.
While inspecting it I found some epoxy covering a plug (see pictures).
Guess previous owner thought it was leaking oil.
Is that plug replaceable?
What is everyone's thought on this?
1983 GPZ-1100 completely stock
1983 Gpz-1100 hot rod build in process
- DoctoRot
Re: Crankcase
25 Sep 2019 13:53 - 25 Sep 2019 13:54
Drill and tap the plug, make a puller to use this tapped hole to pull the plug out. now drill and tap that hole and use a crush washer to seal, or use a pipe tap and a tapered plug. just make sure you clean the gallery real well.
Last edit: 25 Sep 2019 13:54 by DoctoRot.
The following user(s) said Thank You: richard-GPZ
