Delkavic Dissapointment
  • 9er rider
  • 9er rider's Avatar Topic Author
  • Keep a cool tool
19 Sep 2019 15:07 - 19 Sep 2019 15:10
#811060
I thoroughly looked into the Delkavic pipes before buying a set for my 78 1000 ltd. Because removing pipes for an oil change is a PITA. The one thing no one mentioned is to remove the drain plug # 4 pipe has to be removed. Maybe its my fault but That Sucks because I had to touch the pipes. Ive never been Mr immaculate doing an oil change, So if I had Known this I would have gone Kerker. Oh well Bike is sold anyway ,,,, to my son.... I wont buy another set.
Last edit: 19 Sep 2019 15:10 by 9er rider.
  • riturbo
  • riturbo's Avatar
Re: Delkavic Dissapointment
19 Sep 2019 15:18
#811062
Funny back when I was younger taking the kerker off my 550 to do an oil change didnt bother me a bit . Now its the last thing I want to do when doing an oil change .
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Sep 2019 15:29
#811064
My V/H isn't so bad after all. :lol:
  • Dr. Gamma
  • Dr. Gamma's Avatar
19 Sep 2019 15:44
#811066
Same with my Bassani pipe. Pop off 8 springs and remove one bolt and off comes the whole pipe!!!
1986 RG500G 2 stroke terror.
  • bluej58
  • bluej58's Avatar
19 Sep 2019 17:01
#811070
Can't beat stock for oil changes.
78 KZ1000 A2A
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
19 Sep 2019 17:19
#811072
Hmmm. My Kerker does not need to come off for an oil change. I wouldn't like that at all...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • SWest
  • SWest's Avatar
  • 10 22 2014
19 Sep 2019 17:45
#811074
The V/H that made 5% more power had to come off to change the oil filter was more money. The one I have now is a PITA to get to the filter but doable. I miss my cross over 2/1 Jardine "tuned exhaust".
  • perrykz1000
  • perrykz1000's Avatar
  • Have a safe day !!
20 Sep 2019 12:08
#811112
That's weird?? I don't have to remove mine for oil changes & filter????
  • loudhvx
  • loudhvx's Avatar
20 Sep 2019 12:54 - 20 Sep 2019 12:55
#811118
I've been wanting a Delkevic for a 550, but they don't make them. Removal for oil change does suck. As easy as an oil change is to do, I don't seem to ever want to do it.
The Mac header for a 550 does not require removal, but it does feel and sound like a cheap system (because it is cheap).
Last edit: 20 Sep 2019 12:55 by loudhvx.
  • 9er rider
  • Keep a cool tool
20 Sep 2019 16:37 - 21 Sep 2019 07:32
#811128
I cant even get a box end wrench over the drain plug, with out removing the right #4 pipe. Its a good thing I only used A small amount of the silicone on the bend leaving the collecter going to the tail pipe
Last edit: 21 Sep 2019 07:32 by 9er rider.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
23 Sep 2019 05:11
#811187
SWest wrote: ... I miss my cross over 2/1 Jardine "tuned exhaust".
Suspect you mean the 4 / 2 Jardine tuned system system.
A true 180⁰ tuned system with the classic, balanced look of two collectors, one on each side, that paired cylinders 1&4 into a collector @ 180⁰ firing order, and cylinders 2&3 into the other collector, also @ 180⁰. Exemplary street performance. Retained the centerstand, plus easy oil filter & drain plug access. The baffles produce a sweet, deep bass exhaust note without the irritating high frequency component that lesser systems failed to attenuate. The bends necessary to achieve four truly equal-length head pipes resulted in a tangled-looking, asymmetrical headpipe system that's an acquired visual taste. Too, the headpipes were single-wall, resulting in the chrome bluing somewhat at the first bends, something unavoidable on single-wall pipes even with optimum jetting. Overall, the Jardine 4/2 system weighs slightly more than 4/1 systems but, I never cared about a few pounds. The pleasant exhaust note, serviceability and aesthetics were & still are worth it.
Hooker also made a 4/2 crossover system that the headpipe crossovers were perfectly symmetrical at the cost of sacrificing equal length headpipes. I saw far more Jardine systems in the day than the Hookers.
After production of the Jardine 4/2 Z1 systems ceased I tried mightily to make the Jardine 4/2 system for a KZ1000 fit, but the headpipe bends were all wrong. Lacking the skill and/or funds for custom fabrication in the day, I gave up on fitting them to a Z1.
Rumor has it that after Jardine's acquisition by SuperTrapp, the original Z1 4/2 pipe jigs still exist, gathering dust someplace.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • Rick H.
  • Rick H.'s Avatar
23 Sep 2019 06:40
#811194
I wish I would have kept my Denco 4 into one that I had on my Z1B back in the day. Didn't have to take it off to change the oil and it sounded great. Still trying to find a good used one, but I think I will find the proverbial "pot-o-gold" first.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
