KZ1428 Turbo build suggestions anyone?
  • zed1015
  • zed1015's Avatar
Re: KZ1428 Turbo build suggestions anyone?
15 Sep 2019 09:03
#810870
The issue with the second gear input is that the bottom of a couple of the teeth sit very close to the bottom of the internal spline which leaves a very thin cross section in that area which is prone to fracturing that then allows the gear to spread and shatter with bad results for the rest of the gearbox.
It doesn't need the hard shift of an air shifter or the excess load of a car tire launch to split them.
It's common for them to fail on your everyday rider and all it takes is a missed shift or some general hard use for it to go especially with the age and mileage of these bikes and components now.
If i was you i'd buy a fresh billet gear as anything used with an unknown history may be as bad as leaving the stock gear in..
  • asphalt900
  • asphalt900's Avatar Topic Author
15 Sep 2019 09:13
#810872
How True Zed. I just thought the respectable racers here "might" of had a set already and gave-up racing?
