Missing my KZ1000 J cams
  • drdamn
  • drdamn's Avatar Topic Author
03 Sep 2019 13:18
#810292
So I bought an 81 KZ1000 J basket case. And just realized the cams aren't there. I've spent 2 days searching for these things, but all I can find are the police type cams, with the two grooves.
I'm planning on keeping the bike mostly stock for now, but I dont want to take that performance hit. It looks like my only other option would be Web 118 cams. But I really dont want to spend $600.
Anyone have any recommendations, or cams they'd like to sell?
  • baldy110
  • baldy110's Avatar
Re: Missing my KZ1000 J cams
03 Sep 2019 15:42
#810303
What performance hit, the cams are the same. The police bike use the 1000J engines so all parts are interchangeable.
  • TexasKZ
  • TexasKZ's Avatar
03 Sep 2019 20:21
#810326
I think there were at least three different cams used in the J engine.
The lowest lift and duration was for the LTD and CSR. The CSR exhaust cam has a tachometer drive gear that is missing on the LTD cam.
The highest lift and duration was for the GPz.
There was an in between grind for the J model (standard). I suspect this was used in the P as well, but have no confirmation.
  • zed1015
  • zed1015's Avatar
04 Sep 2019 02:43 - 04 Sep 2019 05:30
#810328
Get some stock 3 bolt cams from the earlier motors and some APE adaptor sprockets for the HYVO chain and you will be up and running without much expense
There are tons of early cams about and they are all the same and work well in the J.
Also nearly all aftermarket cams are 3 bolt fitment so if you do decide to go for Web cams or the like in the future you will already have the adaptor sprockets.
Last edit: 04 Sep 2019 05:30 by zed1015.
The following user(s) said Thank You: TexasKZ, drdamn
  • drdamn
04 Sep 2019 12:25
#810347
So are the cams from the earlier engines as hot as the J's? I know the police model cams are a little tamer. I want this thing to rip!
  • drdamn
04 Sep 2019 12:28
#810348
TexasKZ wrote: I think there were at least three different cams used in the J engine.
The LTD and CSR use the same profile as the police model
  • TexasKZ
  • TexasKZ's Avatar
04 Sep 2019 15:03
#810356
Too bad for the cops......
  • TexasKZ
  • TexasKZ's Avatar
04 Sep 2019 15:06
#810357
drdamn wrote: So are the cams from the earlier engines as hot as the J's? I know the police model cams are a little tamer. I want this thing to rip!
If you want it to seriously rip, then you will need some serious aftermarket cams and to spend some serious money on porting, pistons, carbs, exhaust and such.
If you want it to run like Kawasaki designed it to, then the stock cams or the earlier Z/KZ cams are the best bet.
  • baldy110
  • baldy110's Avatar
04 Sep 2019 15:25
#810358
The KZ1000P uses the same engine components as the KZ1000J engine including cams there is no difference in the profile.
  • zed1015
  • zed1015's Avatar
04 Sep 2019 17:20
#810365
Yes!
The only other stock cams with higher lift in any other model are the 83-85 1100A Unitrack or 1100r (same engine in both).
  • Nebr_Rex
  • Nebr_Rex's Avatar
04 Sep 2019 17:52
#810368
Yes!
And the GPz1100 B1 & 2s. Not as hot as the Unitracks. I'll measure mine tomorrow and dig into a manual for some more specs.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • baldy110
  • baldy110's Avatar
04 Sep 2019 18:41
#810372
General rule is ALL KZ cams are the same. The only hotter ones are the GPZ models.
