Missing my KZ1000 J cams
  • TexasKZ
  • TexasKZ's Avatar
Re: Missing my KZ1000 J cams
04 Sep 2019 19:35
#810374
Not according to the specs in the fsm.
  • zed1015
  • zed1015's Avatar
05 Sep 2019 03:35 - 05 Sep 2019 05:51
#810385
Nebr_Rex wrote:
zed1015 wrote:
drdamn wrote: So are the cams from the earlier engines as hot as the J's?
Yes!
The only other stock cams with higher lift in any other model are the 83-85 1100A Unitrack or 1100r (same engine in both).
And the GPz1100 B1 & 2s. Not as hot as the Unitracks. I'll measure mine tomorrow and dig into a manual for some more specs.
Yes! B1 and B2 had fractionally more lift and duration too but hardly worth tracking down for an upgrade that you won't feel..
There's a reason why nobody ever said that stock cams from any other model than the 83 geep are what you need for a power upgrade.
What i should have said was that the 83 unitrack cams are the only stock cams that will give a noticable difference over any of the others.
The stock KZ 3 bolt cams are more than suited as a cheap readily available substitute for the stock J's and won't restrict it's performance.
Last edit: 05 Sep 2019 05:51 by zed1015.
The following user(s) said Thank You: drdamn
  • Nebr_Rex
  • Nebr_Rex's Avatar
05 Sep 2019 20:38
#810423
My cams measured .360 intake and .340 exhaust, same as the 'J' model.
I'll post the specs out of the manual tomorrow.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • drdamn
  • drdamn's Avatar Topic Author
08 Sep 2019 12:17
#810534
Awesome, thanks for all the help guys! I ordered some early KZ1000 cams on ebay and the APE sprockets
  • drdamn
10 Sep 2019 07:49
#810635
So I got a set of 1977 KZ1000 cams. I measured them.
Lift on intake cam: .328"
Lift on exhaust cam: .296"
According to this post
(about halfway down)
The stock KZ1000 J cams should be
Intake .330"
Exhaust .346"
So the intake seems fine, but the exhaust is way off. Not sure what to do at this point besides buy some damn web cams.
