Oil cooler fittings
- Bulletkz
Oil cooler fittings
13 Aug 2019 15:00
I want to add a oil cooler to my 80 kz1000.
I'm building it now the motor is not stock and it gets and stays hot here in Florida.
I found the fittings for sale on a few sites but think the price is way high for just the fittings.
Does the police version come with the cooler fittings? Or any other bikes ?
Re: Oil cooler fittings
13 Aug 2019 15:26
How much is too much?
13 Aug 2019 16:32 - 13 Aug 2019 16:34
The GPz 1100and the ELR had one.
Last edit: 13 Aug 2019 16:34 by TexasKZ.
- Dr. Gamma
13 Aug 2019 19:08
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: ryan79
- Bulletkz
15 Aug 2019 14:17
I found one fittings only on Ebay for $217.00
Z1 sells them for $70.00
I don't think a oil cooler should be a $500. Investment.
I was hoping to spend under $30. For the fittings.
15 Aug 2019 14:24 - 15 Aug 2019 14:25
$70 is about right. I think I paid a little over $50. THAT DOESN'T INCLUDE THE COOLER, HOSE AND PARTS. :whistle:
Last edit: 15 Aug 2019 14:25 by SWest.
- Dr. Gamma
15 Aug 2019 16:22Bulletkz wrote: I found one fittings only on Ebay for $217.00
Under 30 dollars. Thats Funny!!!!!!!!
By the time you buy a high quality oil cooler, AN hose and fittings, and fab up a nice oil cooler mount, plus the fittings, bet you will be real close to 400 bucks or so!!!!
15 Aug 2019 16:40 - 15 Aug 2019 16:41
No eBay APP ID and/or Cert ID defined in Kunena configurationA good used Zephyr 1100 oil cooler is yours for less than 40 bucks.
Last edit: 15 Aug 2019 16:41 by Scirocco.
15 Aug 2019 16:47Dr. Gamma wrote:Bulletkz wrote: I found one fittings only on Ebay for $217.00
I made a cooler setup for a Suzuki GS for quite a bit less than $400. This is a good source for coolers and hose/hose ends... www.anplumbing.com/extras/earls-coolers.html
15 Aug 2019 17:04 - 15 Aug 2019 17:05
My oil cooler Setup was a 100 Euro Investment. The expensive part was the new oil lines for 30 Euro (2 meter of high temp oil line), 10 piece of SS ear clamps 6 Euro.
Last edit: 15 Aug 2019 17:05 by Scirocco.
- Bulletkz
16 Aug 2019 10:13
I meant for just the fittings to the motor.
I have everything else sitting around from car builds. Probably use a custom trans cooler.
16 Aug 2019 10:23
