- Thank you received: 35
82 GPz 1100 ...new valve guide seals, still smokes bad
- Gdailey2112
- 82 KZ1100D1
Anyway, ...the problem is that it smokes like a SOB. Bluish grey smoke. I'm puzzled. Any help would be appreciated. TY
1982 KZ1100D1
- Nerdy
- Thank you received: 410
The likely candidate is the piston rings being worn, stuck, or possibly broken. Did the bike sit without running for a long time?
It is also possible (though less likely) the new valve guide seals were faulty from the factory.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- gordone
- Thank you received: 67
Leak down test?
Project:
- Gdailey2112
- 82 KZ1100D1
1982 KZ1100D1
- ned37
- Thank you received: 11
'83 GPZ1100, '97 Triumph Trophy 1200, '08 Husky TE610
Verde Valley, AZ
- Kofla
Gdailey2112 wrote: Pulled the plugs, cyl #2 is the only wet oily plug. I'm pulling the head tonight (again!).
Before tearing down the head, why don't you do an engine leakdown test? Spend a little cash on a leakdown tester and you could save a lot of time and money.
1978 Kawasaki KZ-1000 LTD
- Thank you received: 2818
- Thank you received: 2746
- Thank you received: 2063
- loudhvx
- Thank you received: 1616
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- Gdailey2112
- 82 KZ1100D1
1982 KZ1100D1
