Kz 1000 police piston rings
- Zilla
Re: Kz 1000 police piston rings
19 Jul 2019 05:40
Ok , I guess I’ll be taking it apart to see what the what is. Is there a way for me to measure it or should I take it to a machine shop. And just say it’s in spec and only needs to be honed would that keep me in the standard ring size or go up a little, cause to be honed is to lose a little cylinder wall correct or no?
1986 KZ1000P
2005 Vmax
2005 Vmax
19 Jul 2019 05:58
Take it to a machine shop. This requires very accurate measurements at several points in the bore. The only way to know if over sized parts are needed is to make the measurements.
- Zilla
19 Jul 2019 06:27
Ok then that’s what I’ll do, in the mean time is it safe to drive it or can low compression cause some more damage internally, don’t want to cause more problems. The reason I ask is my wife likes driving it we sometimes go riding together. I’ve tied getting her to ride my Vmax but it’s little to heavy for her.
1986 KZ1000P
2005 Vmax
2005 Vmax
- Zilla
19 Jul 2019 06:44TexasKZ wrote: Take it to a machine shop. This requires very accurate measurements at several points in the bore. The only way to know if over sized parts are needed is to make the measurements.
The reason I asked bout in the mean time I have one more rotation at the mill then I’m on vacation and was gonna break it down then, she’ll probably wanna ride before I do that , and while I’m running it threw my head is it possible to pull the head from the block while it’s in the frame or would I need to pull it. I appreciate everyone’s help by the way.
1986 KZ1000P
2005 Vmax
2005 Vmax
19 Jul 2019 07:26
It is probably OK to ride, but keep a close eye on oil consumption. Yes, you can pull the head and cylinders with the engine in place.
- Zilla
19 Jul 2019 07:32TexasKZ wrote: It is probably OK to ride, but keep a close eye on oil consumption. Yes, you can pull the head and cylinders with the engine in place.
Ok well that’s the plan and I will post what comes of it. Maybe I won’t find anymore surprises when I goin threw it. When it’s all done what PSI should I look for
1986 KZ1000P
2005 Vmax
2005 Vmax
19 Jul 2019 08:03
If the cylinders only need to be honed you can stick with standard rings.
I don't know what compression you would see on a new engine (check your book) but you should be close to that number when you do the rings, unless you also have valve issues.
Normally when you pull the cylinders you would check out everything else you can check. Valve guides, seals and seats for starters. If you're doing the work yourself you will need a set of top end gaskets. I would buy OEM to ensure quality.
Be sure to take plenty of photos as you dismantle things. And buy a box of baggies to put parts into so you don't lose anything. I usually label the baggies as well.
- Zilla
19 Jul 2019 08:10hardrockminer wrote: If the cylinders only need to be honed you can stick with standard rings.
Ok I’ll check my book, I plan on doing it myself all but the honeing part, so I’ll have to read my book. I recently sold my 83 V65 Magna but when I had it I did replace the cap on top of the valve spring and the keepers so I have an idea but not completely sure of it all. I have the cylmer manual to look threw as I go but definitely the pics and baggies.
1986 KZ1000P
2005 Vmax
2005 Vmax
19 Jul 2019 13:49
You can also use the standard KZ factory service manual for most things. You can downlaod the 1981-83 manual from this site. It would be a good idea to chase down a copy of the police supplement for your year. The Clymer is better than no manual, but the factory manual and supplement are more specific, and usually more detailed.
The following user(s) said Thank You: Zilla
19 Jul 2019 16:06
The service manual details how to check the cylinder bore but I would recommend you make a copy of it and give it to an experienced machinist to do. He can do the honing as well. Well worth the expense.
- Zilla
19 Jul 2019 16:36TexasKZ wrote: You can also use the standard KZ factory service manual for most things. You can downlaod the 1981-83 manual from this site. It would be a good idea to chase down a copy of the police supplement for your year. The Clymer is better than no manual, but the factory manual and supplement are more specific, and usually more detailed.
I found one factory supplement for 1975 to 1985 Police, would that cover an 86?
1986 KZ1000P
2005 Vmax
2005 Vmax
19 Jul 2019 16:47
This Service Manual will cover your engine rebuild
kzrider.com/modules/ServiceManuals/Kawas...Service%20Manual.pdf
