Engine sound
  • gordone
  • gordone's Avatar Topic Author
Engine sound
10 Jun 2019 06:38
#805448
Prepare for weekend trip next weekend.
What do you think about the sound?
I have the mic first on one side of the engine and then on the other side, over sparkplug 1 and 4.
streamable.com/vsfrm
Project:
  • gordone
Re: Engine sound
10 Jun 2019 13:38
#805459
I have checked the valve today, and two was to loose, or almost outside the limits...
Maybe the sound will be tter now?
I don`t think the sound was bad, but it was maybe some valve sound ?
kzrider.com/forum/11-projects/607213-650...gine?start=80#805458
Project:
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Engine sound
10 Jun 2019 14:11
#805462
Gordone, do you have re-check the carb sync??? I my opinion the engine idle rev is a little to high too.
  • gordone
Re: Engine sound
10 Jun 2019 14:35 - 10 Jun 2019 14:36
#805465
Scirocco wrote: Gordone, do you have re-check the carb sync??? I my opinion the engine idle rev is a little to high too.
I have not check carb sync after re shimming the valve, will do that. Must take it on day time, to much sound for afternoon between the houses :)
The RPM say 1 on idle, but maybe it`s off ?
What is the benefits of having lower idle?
Project:
Last edit: 10 Jun 2019 14:36 by gordone.
