650 SR 1981 (z750L engine)
  • gordone
  • gordone's Avatar Topic Author
Re: 650 SR 1981 (z750L engine)
10 Jan 2019 11:54
#796494
Today have I test mounted the new exhaust, it looks to fit perfect. I have now packed down again and will sent it coating tomorrow.
I will properly not be able to install it before I take the bike out from the storage room in April? I`m afraid of damage it when it move the bike out :)
Project:
  • gordone
13 Jan 2019 06:13
#796663
These weekend have I balanced my wheels, last winter I replaced the tires without balancing the wheel. I have had some vibration when I have driven... not so heavy that I have done something with it... hopefully is that away now... will be interesting to drive when the season start and see how they perform.
I also did some easy polishing on the rims.
Project:
  • gordone
07 Feb 2019 06:59
#798322
Today have I installed washers on the front fork suspension between the progressive spring and the top cups.
I have missed these part...
I also took some measurement on how much the progressive spring is pushed down when there is not weight on the spring (lifted up the frame in the front).
Project:
  • gordone
09 Mar 2019 07:57 - 09 Mar 2019 08:03
#799987
I have never liked the front fender, the way its mounted to the bracket with 4 bolts and nuts....
I found a new fender on eBay from a kz750 1981 model, I have sanded the fender primed and painted it with new black color.
Sprayed some body spray (dry) to avoid corrosion in the inside of the fender.
I absolutely liked the results, much more clean design "follow" the wheel better...
One task left on the fender I need to make some more space for the brake lines, so they don`t damage the paint when I use the bike.
Project:
Last edit: 09 Mar 2019 08:03 by gordone.
  • ajsfirehawk
  • ajsfirehawk's Avatar
09 Mar 2019 08:07
#799988
Really good work and coming along nicely. All of us well north of the equator are like you, anxiously waiting for Spring. Keep the updates coming.
79 KZ650 SR
80 KZ1000 Z1 Classic
83 KZ1100 LTD
Z900RS
23 Mach 1
  • gordone
09 Mar 2019 08:18
#799993
ajsfirehawk wrote: Really good work and coming along nicely. All of us well north of the equator are like you, anxiously waiting for Spring. Keep the updates coming.
Thank you, yes I`m also looking! so forward to the spring :)
Hope the engine start.. heheh have new exhaust to be installed when I have taken the bike out...
Project:
  • martin_csr
  • martin_csr's Avatar
09 Mar 2019 08:31 - 10 Mar 2019 06:11
#799996
By gordone: I have never liked the front fender, the way its mounted to the bracket with 4 bolts and nuts....
I've never seen a fender like that with fasteners on top. so then I checked partzilla & sure enough, that's how some were done. weird.
Last edit: 10 Mar 2019 06:11 by martin_csr.
  • rstnick
  • rstnick's Avatar
09 Mar 2019 16:00
#800020
Just the D model 650s were like that I believe.
Coming along well Gordone.
B)
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
  • gordone
24 Mar 2019 08:49 - 24 Mar 2019 08:51
#800958
Today have I replaced broken lightbulbs in the instruments.
Starts to got close to season start :)
Install exhaust and fasten the front brake lines, and then be good to go :)
Project:
Last edit: 24 Mar 2019 08:51 by gordone.
  • gordone
25 Mar 2019 11:50 - 25 Mar 2019 11:52
#801021
I have had problem with the brake lines touch the mud cover, I ordered some spacers on eBay and painted them black, I think the problem is solved now.
I have gotten some help here:
www.kzrider.com/forum/5-chassis/609666-b...uch-mud-cover#801018
www.kzrider.com/forum/5-chassis/610212-what-is-these-called
Project:
Last edit: 25 Mar 2019 11:52 by gordone.
  • gordone
06 Apr 2019 07:13 - 06 Apr 2019 15:20
#801625
Today took I the bike out for the first time from winter storage, spring is here now :)
I installed the new exhaust system, happy with the results. I also flushed the gas tank with new gas (have stored it with WD-40).
Looking forward to start up the bike with the new exhaust system, maybe tomorirow :)
Some picture from todsys work:
Project:
Last edit: 06 Apr 2019 15:20 by gordone.
  • gordone
09 Apr 2019 14:31
#801890
Had my first test drive for the season :)
The bike worked really well!
Lovely to crusing in high speed without vibrations :) the wheel balacing i did in the winter worked :)
The tacho meter was not working, wire was broken so have order new...
The speedo meter was also steady.., have jumped around before! Greasing the cable have fixed it.., thank you for the help there :)
Project:
