Damaged threads to spark....
  • Nessism
  • Nessism's Avatar
Re: Damaged threads to spark....
31 May 2019 14:46
#804963
One of the risks with installing inserts is if they are installed crooked, which is easy to do.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
31 May 2019 15:52
#804965
Do as i PM you and follow the same advice like Nessism wrote, go the safe way first.
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
31 May 2019 16:02 - 31 May 2019 16:05
#804967
The tool Patton discribe is very helpful, but if a lot of aluminum is riped out only a Time-sert will cure the prob.
Pattons tool only reform the threads without any cut off aluminum.
BTW, where can i buy this the reverse threading tool??? I am a must have tool junkie!!!
Last edit: 31 May 2019 16:05 by Scirocco.
  • gordone
  • gordone's Avatar Topic Author
31 May 2019 23:59
#804982
Scirocco wrote: Do as i PM you and follow the same advice like Nessism wrote, go the safe way first.
I think I need to try myself first :)
It’s not quick to to deliver the bike to workshop.
What equipment are workshop using when you are not taking off the top?
Project:
  • gordone
03 Jun 2019 14:31
#805088
Today I received the Wurth timecert kit, and I installed one insert in the cylinder 2, and from my understanding the results is good, no leak and the bike running fine....
www.kzrider.com/forum/11-projects/607213...gine?start=80#805086
Thank you all for your help an d input!
A good feeling to be able to fix things by your self :)
Project:
  • bluej58
  • bluej58's Avatar
03 Jun 2019 16:51
#805104
Right on!
78 KZ1000 A2A
