82 KZ750-What are these supposed to sound like
  • Saxobass
  • Saxobass's Avatar Topic Author
18 May 2019 13:48
#804099
pardon the potentially really stupid question but this is my first UJM and I honestly don't know. What are these things supposed to sound like? Is there a lot of mechanical noise? I've spec'd the valves with new shims and just tensioned the cam chain with a manual APE tensioner. Everything seems to be running fine but it kind of sounds like a sewing machine. Is this normal?
1982 KZ750 H3
-Wiseco 810 kit
-Dyna S pickup
-Dyna coils
-Motogadget M-Unit Blue
-Revival Cycles starter solenoid
-Kz650 Kickstarter
-Progressive fork springs
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: 82 KZ750-What are these supposed to sound like
18 May 2019 14:23
#804100
Be sure you don't have the cam chain too tight.
The following user(s) said Thank You: Saxobass
  • JR
  • JR's Avatar
18 May 2019 15:56 - 18 May 2019 17:07
#804108
The 750/4s have a primary chain which will rattle quite a bit if the carbs are out of sync and a bit less if synced but they are still a noisey air cooled 4 cyclinder UJM and will never sound as quiet as a modern liquid cooled motor.
Mine has been rattling away happily for the past 16 years and 50,000 km.
Last edit: 18 May 2019 17:07 by JR.
