KZ650 H1 Jerky wide open, choppy low rpm.
- agrestixrock
17 Apr 2019 06:49
i recently installed a 4 to 1 header on my 81 KZ650 H1. i got this off of a 77 KZ650. both bikes have mikuni carbs. not sure on the #s though, the carbs on my 81 have the accelerator pump on the #2 bypassed because the person i got it from lost the cover so i put a different float bowl on it and capped the nipples that go between the carbs. before installing the header it ran pretty well from what i know. but now it shows signs of being both too rich and too lean. when it warms up it still wants half choke to run half decent. before i played with the choke i just set the idle higher to conpensate the rougher idle. when i was running it with no choke id get off and my boot would have oil all over the toe, my oil pan is leaking but since running it half choke there is little to no oil on my boot. i looked at the jets in both carbs and only the main jets were different. my 81 has 95 main jets and the bike i got the header off of had 110 mains. i checked my spark plugs and 2 were white which i know is lean, 1 was white but slightly the toasty brown so its close but still a little lean (this was the #2 the main carb), and the last one was black which is rich. last night riding home i tried to take off from a stop light quickly and when i hit full throttle it started jerking like i was riding a bull. im just thinking itd be easier to put the carbs off of the parts bike and putting them on because it was probably jetted for the exhaust im just sure
Re: KZ650 H1 Jerky wide open, choppy low rpm.
17 Apr 2019 07:43
The pump was to compensate for a leaner setting on the later carbs. Often the slides have a leaner cutaway so the pump is needed. If you have earlier carbs they would be your best bet being they were setup for the exhaust. Pics would be helpful.
- gd4now
- Denco where did you go?
17 Apr 2019 10:23
You do not mention if any changes have been made to air intake or not. If you are running the stock air box then I would think that the parts bike carbs with 110 mains would be somewhat rich.
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
- agrestixrock
13 May 2019 09:51
i will get some pics ASAP. i have not made any changes to the air intake. both bikes had pods when i got them. i think im going to take the old ones and put it on my bike to see what happens. the plugs are all different colors. #1 was dark brown, #2 was white, 3 was really dark and had build up, 4 whas white. still very choppy after i adjusted the air intake screws. this morning it ran fine after a week of sitting about halfway to work then it started jerking again.
- Warren3200gt
13 May 2019 10:34
If the plugs are all different colours maintainence has been serverly neglected. Get a manual and do EVERYTHING. You'll probably find most of your issues will disappear.
The following user(s) said Thank You: agrestixrock
- agrestixrock
13 May 2019 16:15
i had it set up pretty well before i put the header on but since the exhaust was technically 2 pipes before and now everything is going into one its been a nightmare. i did have leaky carbs and it would still occasionally jerk at the top end probably because my accelerator pump was bypassed. when i got it it was a wreck and i downloaded the manual and have done almost everything i could. before i could ride all day on a hot day and not worry about it. but now its like a war inside my exhaust in the pictures, the first two are the current carbs with the "bypass" and the last one is a picture of the carbs that came off the bike i got the exhaust from. mines an 81 and the parts bike is a 77
13 May 2019 19:42
Sounds lean to me.
14 May 2019 13:03
Your carb bowls are leaking, fuel level is too high. Carbs need new bowl gaskets.
Old vaporised fuel covering the carb bowls and engine.
Have you check the fuel Level? Are your intake boots soft and not hard and brittle?
- agrestixrock
18 May 2019 10:45
i need new float bowl gaskets i know that the carbs from the donar bike have gaskets that look almost new. i cleaned them up and when i hooked them up they were pooring gas out. looked like from the passages between the carbs. it ran great but couldnt ride it because of how bad the fuel was leaking. anyone know any fixes for the rubber fuel rails? theyre just a metal tube wrapped in rubber that have bumps in them like o rings
18 May 2019 12:51
I fix my rubber fuel rails (T-inlets) with electric wiring shrink tube.
- agrestixrock
18 May 2019 14:33
i did try that but it was slightly too big to cram into it but ill give it a shot with some different stuff
- agrestixrock
21 May 2019 19:28
okay so i changed out the float bowl gaskets, applied a very thin layer of fuel lube to them to make sure they seal very well. doesnt leak anymore but now im having symptoms of a vacuum leak. guessing my carb boots because i bumped the carbs while it was idling and it died and wouldnt want to start. do i have to have the kawasaki carb boot clamps or will just cheap ones from the parts store work?
