Clutch Drive feels sloppy '81 KZ440D
- dsr9024
23 Mar 2019 13:46
Had to do some work with the clutch and got to turning the Clutch Drive (i believe thats what it is at least) and noticed i can turn by hand maybe an 1/8th of a turn before it "hits" anything, is this normal?
Re: Clutch Drive feels sloppy '81 KZ440D
23 Mar 2019 18:20 - 23 Mar 2019 18:21
I don't understand what you're turning. Are you talking about the clutch release adjusting screw?
The diagrams at Partzilla are handy for stuff like this.
Last edit: 23 Mar 2019 18:21 by martin_csr.
- dsr9024
23 Mar 2019 20:51
Sorry i wrote clutch drive because that was all i could find as to what it was but its the splined rod that the clutch "cage" slides onto if that helps any.
23 Mar 2019 21:21
If you are talking about the free play back and forth, that is probably normal.
24 Mar 2019 06:44
Perhaps a picture would help clarify matters. Also, the proper names of things can be found in the factory service manual, and in the parts diagrams at Kawasaki.com and Partzilla.
- Warren3200gt
24 Mar 2019 07:18
With just the clutch basket fitted so you can see the shaft end. If you rock the basket back and forth can you see any play on the shaft? I suspect you are seeing normal gearbox play.
