Cam restoration?
  • kzsolo
  • kzsolo's Avatar Topic Author
Cam restoration?
26 Feb 2019 14:42
#799276
'78 KZ750 Twin. When I rebuilt the top end I check the cam heights. Three lobes were right at the service limit and the left exhaust lobe was below the service limit. I asked several Ebay sellers to tell me what the cam height specs are. Everybody tells me they can't share that info 'cuz the cams are in a warehouse somewhere. So my question is - can a cam lobe be welded up and re-machined?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: Cam restoration?
26 Feb 2019 16:02
#799286
Long Story short, yes but it will be expencive.
I would try to buy a spare one, it is cheaper.
The following user(s) said Thank You: kzsolo
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Feb 2019 16:50
#799288
If they want the sale they'll work with you or move on.
The following user(s) said Thank You: Nessism, kzsolo
  • Nessism
  • Nessism's Avatar
26 Feb 2019 17:01
#799289
As long as the lobe isn't scored it won't hurt anything if there is a little wear. The cam to bucket/shim contact area is large and flat so any wear will be uniform across the cam. I'd be more concern if the journals are worn, either the cam or the head. You might want to try some plastigauge to check clearance.
  • DFIGPZ
  • DFIGPZ's Avatar
26 Feb 2019 17:12
#799290
Nessism wrote: As long as the lobe isn't scored it won't hurt anything if there is a little wear. The cam to bucket/shim contact area is large and flat so any wear will be uniform across the cam. I'd be more concern if the journals are worn, either the cam or the head. You might want to try some plastigauge to check clearance.
+1
1984 750 Turbo
  • TexasKZ
  • TexasKZ's Avatar
26 Feb 2019 17:38
#799293
Might not hurt to call if you are really interested.
megacyclecams.com/catalog/Page45.pdf
  • kzsolo
27 Feb 2019 12:51
#799343
I used the same caps with the same cams. The head I got from ebay had less miles so clearance was actually better than the old one.
  • kzsolo
27 Feb 2019 12:53
#799344
TexasKZ wrote: Might not hurt to call if you are really interested.
Good idea. Can't hurt.
  • DoctoRot
  • DoctoRot's Avatar
28 Feb 2019 00:44 - 28 Feb 2019 00:47
#799382
I bought a set of race cams for a kz750 twin that turned out to be junk. The journals were completely pitted. Megacycle wanted to $650 to repair. If you're spending that much might as well get some decent cams on ebay and send them out for a regrind with a better profile which is what I did.
If you still need some stock cams I have quite a few laying around.
Last edit: 28 Feb 2019 00:47 by DoctoRot.
The following user(s) said Thank You: Street Fighter LTD, SWest
  • kzsolo
02 Mar 2019 15:12
#799539
DoctoRot, I am interested in a pair of stock cams. PM me with a price. BTW - I am curious as to the profile you used. How did it change performance? Thanks.
  • kzsolo
08 Mar 2019 11:03
#799938
DoctoRot wrote: I bought a set of race cams for a kz750 twin that turned out to be junk. The journals were completely pitted. Megacycle wanted to $650 to repair. If you're spending that much might as well get some decent cams on ebay and send them out for a regrind with a better profile which is what I did.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Mar 2019 11:18
#799940
If you're talking about his avatar, if that thing was on my foot the bike would have to catch me. :woohoo:
